uklee70
posted on 6/8/09 at 03:22 PM |
Speedo Healer Help
Hi All
I have My SVA re Test wednesday !!!!!!!
Can anyone help with my speedo healer V2
The speedo reads 10mph when My GPS reads 30mph
I have gone to the online calc and I think I'm having a blonde moment
what figure goes where
Lee
jack_t
posted on 6/8/09 at 03:46 PM |
that any help
james h
posted on 6/8/09 at 04:17 PM |
You will need to check if your version of speedohealer can be calibrated by 200%. The pic above seems to show v4
Can you add a magnet (if thats how your speed pickup works)?
Good luck with your retest
James
StevieB
posted on 6/8/09 at 08:54 PM |
What you need to do is reset your speedohealer to wipe the memory (turn of ignition, set all switches to ON, turn on ignition, press button once, set
all switches to OFF).
Then check the actual speed v indicated.
What I did was then have a crack at various %age reductions until I got within tolerance.
What I worked out is:
Switch 4 reduces by 10's of %'s
Switch 5 reduces by 1%'s
Switch 6 reduces by 0.1%'s
So, if you need to reduce by 65 %, do the following:
Turn off ignition
Set all switches to ON
turn on ignition
press button once
Set all switches to OFF except no.4
press button 6 times
set switch 5 ON, 4 OFF
press button 5 times
set switch 5 to OFF
That will give a 65% reduction - you should be able to follow the pattern from there to try different adustments to hone in on the correct reading.
You must reset the unit every time and adjust on a comparison of the base eadings, not the adjusted readings
Hope that makes sense/helps in any way.
StevieB
posted on 6/8/09 at 08:57 PM |
Actually I've just realised I have to drop my son off at my In-Laws early at morning (Scarborough) so if you're still having troubles I
could tak a detour and give you a hand if you need it.
uklee70
posted on 6/8/09 at 10:03 PM |
Hi Thanks for the replies
I have been on the sites and my heeler is either V1 0r V2
So I'm not sure how much adjustment I I have with this version
As for magnets I went from 8 to 4 to get the speedo to read a steady speed and not jump all over the place.
Having looked at the calcs I'm going to try more magnets to get within the calibration range or buy a V4 heeler
Any tips on getting the magnets exactly right !
Lee
