Author: Subject: Camshaft timing(Peugeot engine)
locosaki
posted on 12/8/09 at 09:36 PM Reply With Quote
I've just been taking cam timing figures from my brothers MI16 engine after he rebuilt the engine,The car went good before hand so we just put it back to orginal timing marks.Anyhow I got the DTI gauge today and timing disc just to ensure all figures were correct before dropping engine back in the car.Now when I set the timing on my locost I'm certain the inlet valve starts to open before TDC,However on this Peugeot we have 0.050 lift at 14 degrees after TDC,Anyone know if this sounds correct.
If anyone knows anything about these mi 16 motors feel free too add,I know very little !!!
Regards Mike
clairetoo
posted on 13/8/09 at 06:20 AM Reply With Quote
Are they hydraulic tappets - if so , they will need to be `pumped up` , or the timing checked at peak lift (lobe centers) . I think...........
Its cuz I is blond , innit
Claire xx
Will weld for food......
f750sgr
posted on 13/8/09 at 08:49 AM Reply With Quote
How far before TDC is it. Remember pistons are almost stationery BTDC and have very little movement for a short period ATDC. Having valves closed on the down stroke will cause a vacuum in the cylinder, which may or may not be the desired effect.
Most engines have different requirements.
posted on 13/8/09 at 09:52 AM Reply With Quote
Claire is spot on, they do have hydraulic followers and they have very likely bled down whilst the engine was stripped.
clairetoo
posted on 13/8/09 at 04:14 PM Reply With Quote
So it's a degree wheel on the crank , set TDC very accurately , then check the cam position either side of peak lift with a dial gauge on the cam follower........a bit of maths , and set them to around 110 degree's.......not quite a five minute job
Claire xx
locosaki
posted on 13/8/09 at 09:21 PM Reply With Quote
Hi Guys,
I contacted HiFlow Heads today who are quite well known pug engineers up my way,Anyway I was told that the best way to set up the MI motor is to measure lift at TDC,The lobe centre method is apparantly a little bit hit or miss on the MI,Anyway it turns out my first readings were incorrect,I did infact have 0.020 lift at TDC,To get good power lower down the rev range I'm looking for 0.060 lift at TDC which in turn will bring the lobe centres closer together.I got the car timed up tonight as it has verniers o it made the job a little easier,Still took a few hours though,Thanks for your help.
Craig
