Author: Subject: Water Temp on Zetec Engine ?
Scoobythedog
posted on 16/8/09 at 04:03 PM Reply With Quote
The sensor is located between the water pump and the expansion tank,
What temperature should it settle at when its running well ?
Scooby
madteg
posted on 16/8/09 at 05:48 PM Reply With Quote
Mine runs at about 92 deg
fatbaldbloke
posted on 16/8/09 at 07:48 PM Reply With Quote
The Zetec is generally regarded as quite a hot running engine. 92-98 is a good stable temperature, but it's quite happy to run up to 105 before the cooling fan cuts in. This does mean though that it's important to use anti-freeze/high temp additives in the cooling water.
