s2gse
posted on 16/8/09 at 08:09 PM |
oil levels
looking for some help on oil level for a GSXR1000
the story so far
i had an engine let go and think it was caused by oil starvation
so finally finished fitting a new engine today
had first run today but noticed two issues
1. slight clutch slip when engine hot and when changing gear at above 7000 rpm
2. checked the oil breather pipe and a slight white film around the inside of the pipe ( feels soapy )
i was told to run the engine at 3000 rpm and fill the oil upto full while running the engine it took 4.5 ltrs doing this
the manual said 3.5 ltrs
so the engine has about a 1 ltr more could the above problem be caused by this with the oil foaming when hot
the oil pressure gauge goes from 10psi at 1500rpm to 80psi at 10000rpm i didnt go any faster as not sure if this was right
hope this is clear as i dont want to blow up another engine
please help
gary
life's to short and so was the drive
Dingz
posted on 16/8/09 at 10:04 PM |
Usually overfilling an engine with oil, unless it is a dry sump is a recipe for disaster! The crank dips in the oil and whips it into a nice souflle.
mark chandler
posted on 17/8/09 at 07:40 AM |
Also clutch basket gets immersed in oil causing slip
