jonno
posted on 17/8/09 at 07:33 PM |
Turbo exhaust manifold advice
Hi, i'm thinking of using a turbo on my project and spotted
THIS on ebay...Its not what i want as i'm using a different engine, but looks like a easy
design to make !!, how do you people think it flow, problems etc.
Any advice welcome please
having fun on a budget
Guinness
posted on 17/8/09 at 07:45 PM |
Dunno, but what is the exhaust port spacing and diameter of a GSXR compared to the ZZR? ![](/images//smilies/bigsmile.gif) ![](/images//smilies/shocked.gif)
Mike
twybrow
posted on 17/8/09 at 08:12 PM |
I thought for a turbo, the manifold design is far less important than a NA manifold. It will sure as hell work better than no turbo/manifold!
blakep82
posted on 17/8/09 at 08:21 PM |
looks alright, and easy enough to copy probably doesn't flow very well, but probably not an issue for a turbo
________________________
madteg
posted on 17/8/09 at 08:44 PM |
What engine are you using ?
Antnicuk
posted on 17/8/09 at 08:56 PM |
that will work fine, its exactly the same design i used when i turbo charged my bike.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
jonno
posted on 17/8/09 at 09:13 PM |
Suzuki swift gti (G13b) with Sj413 gearbox.
Hoping for about 150bhp ish with a turbo
Davey D
posted on 18/8/09 at 10:21 AM |
that is just like a log style manifold. if making one for a car that bolts to the block with a flange they are usually made with 2x T pices, and 2x
elbows. Simple, cheap, yet effective
liam.mccaffrey
posted on 18/8/09 at 12:13 PM |
Corky Bells book on turbos will tell you that manifold is ok iirc.
Cracking book even if you're no going forced induction
Build Blog
Build Photo Album
jonno
posted on 18/8/09 at 05:27 PM |
Sounds like the way forward then.
Thanks people
Antnicuk
posted on 19/8/09 at 08:35 PM |
i didnt realise it was on a car engine, you may want to put it the other way up so the turbo is pointing up, if you dont get the lowest point of the
turbo higher than the highest point in the sump you can get problems with not draining the oil back into the sump.
Volvorsport
posted on 19/8/09 at 09:41 PM |
put the turbo flange on the side - thats how most are , ssac manifolds have a habit of falling apart tho if not braced properly .
if you can weld and are making your own - use weldable bends from plumb center schedule 10 or schedule 40 .
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 19/8/09 at 10:55 PM |
So do their turbos, or at least the ones they used to supply. The compressor housing was made in two halves and epoxied together!
NS Dev
posted on 20/8/09 at 06:24 AM |
ssac?
Is that the same as XS Power?
Don't know, but my mate's kadett used an XS Power manifold to start with and we've got rid now, kept cracking. Was very cheap though
so yer pays yer money, I wouldn't have wanted to make one for the price he paid for it!!!
He's got an XS Power hybrid t3/t4 9 i think) turbo though and that was £140 brand new and just flatly refuses to blow up after 3 years drag
racing and road use!
jpindy3
posted on 20/8/09 at 09:22 PM |
its just as inportant,all depends on what power you want.a simple log manifold like in the pic is subjected to high polse's around the
outlet,like with mine if i could use a 2wd cosworth manifold i would as the runs to the turbo are split in two witch flows better.but like all kitcars
there are space problemsu
iti_uk
posted on 21/8/09 at 01:34 PM |
jpindy3 is right, exhaust manifold design is just as important for a turbo application as it is for a naturally aspirated application. The problem is
that, since your new turbo will be forcing more mmix into the cylinders than stock regardless of flow quality, you will see a jump in power over stock
and think "wow, that's excellent", when in fact you could be dropping a whole load of potential by having a poorly designed
manifold.
The manifold pictured on ebay looks a bit pants to me - just by looking at it you can see that you've got two flow-paths opposing each other
right before the turbine flange. Of course, the gas will flow out through the turbo, but it will have lost a whole load of energy having to turn
against an opposing flow, escaping radially from the "cross-pipe". A far better design would direct the flow towards the flange, not past
it, and would probably look more like a short version of a good NA manifold.
Something like this would be good;
http://media.photobucket.com/image/shorty%20turbo%20manifold/SLSfabrication/Turbo%20Manifolds/HPIM3309.jpg
Of course, wastegate placement is also very important, but that's for another thread.
If you have space to do it, make something like the one in the above pic. Packaging issues may force you to make a not-so-good manifold, but if you
can it will pay to do it properly.
Chris
