greed1
posted on 18/8/09 at 04:02 PM |
x flow bike carbs
yes i gave in to the advice again
is this any gud for a 1600 ported to a 1700
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130319763605&ssPageName=STRK:MEWAX:IT
if not what do i need to look for
what parts do i need on the carbs
thanks
Drive it stright sideways
will121
posted on 18/8/09 at 04:53 PM |
you after carbs or throttle bobies? bit ott i would say and cant be split if carbs ZX6 seem popular
greed1
posted on 18/8/09 at 05:18 PM |
oh soz
carbs i am after wrong link
are these throttle bodys
so confused
[Edited on 18/8/09 by greed1]
greed1
posted on 18/8/09 at 05:22 PM |
r these carbs ??
would the work ok
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320411318518&ssPageName=STRK:MEWAX:IT
greed1
posted on 18/8/09 at 05:29 PM |
found a zx6r
but has no tps what eva that is
is it important do i need to get one with it
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280383530947&ssPageName=STRK:MEWAX:IT
blakep82
posted on 18/8/09 at 05:58 PM |
tps is a 'throttle position sensor' used by most ignition systems to help calculate the ignition advance needed.
if you intend on using megajolt, you'll be better off with carbs with a tps. no major problem if not, theres other ways to get the same effect.
________________________
blakep82
posted on 18/8/09 at 05:59 PM |
quote: Originally posted by greed1
r these carbs ??
would the work ok
these are carbs, and they've got the tps (the wire with plug hanging off the end)
greed1
posted on 18/8/09 at 06:58 PM |
is the tps needed
or can i do with out it
if i run bike carbs do i need a megajolt ??
greed1
posted on 18/8/09 at 07:19 PM |
can i not just run a bike carb on its own like a weber carb
if not how much is this sort of system going to cost me
thanks graham
posted on 18/8/09 at 08:59 PM |
You can run with bike carbs without a TPS when you use something like Megajolt - it's called a 2D map (two dimensional). This adjusts the
timing using only the rpm input.
But it is better to run with a 3D map, using something that tells the ignition controller the load on the engine - this can be the tps, which shows
how wide-open the throttle is, or MAP, which shows how much vacuum is in the inlet manifold.
TPS is the easiest option as it's purely mechanical, but MAP is probably the most accurate. Ideally you need one or the other.
will121
posted on 18/8/09 at 09:15 PM |
you can run bike carbs with your existing ignition system as you say as a normal webber would, if you are using a normal coil/distributer in that case
TPS would not be necessary but if carbs had it wouldnt be a bad thing. ZX6 carbs are about 38mm bore, dont know about R1's but would say must be
42mm ish which is large, any idea what you engine is putting out at mo?
jedi
posted on 18/8/09 at 09:18 PM |
i have a bike carb setup for sale zx6r carbs on a steel manifold well setup been on my 1700 xflow for a while now and have prooved faultless only
selling due to engine change
greed1
posted on 18/8/09 at 09:24 PM |
u2u sent
this is what i am looking for
ty
