jpindy3
posted on 19/8/09 at 10:26 AM |
alternater help denso
i have a denso alternater what do i do with the 2 spade coneters, what one is for the feild wire
Mr Whippy
posted on 19/8/09 at 10:31 AM |
is this it?
or this?
[Edited on 19/8/09 by Mr Whippy]
posted on 19/8/09 at 10:59 AM |
I may have posted on this already as I have one fitted.
here
they come with a plethora of different regulators - flakmonkey has posted a linky to some site in australia shjowing these,
mine seemingly comes from a forklift and has one bolt on connector plus two 4.7 mm spades.
spades, when view from the back, are in a T - the top horizontal is for the 12 V switched ignition and has IGN, the vertical one is for lamp.
I am using LED lamp and without the IGN connected, lamp does not go on.
When running, LED lamp goes off so altough I have not checked the alternator output - is on the todo list - I am reasonably confidnet it does what it
says.
Note I am writing this all from memory so may have details wrong hence check the flakmonkey post.
[Edited on 19/8/09 by 02GF74]
