aaron bassett
posted on 2/9/09 at 07:33 PM |
ignition system
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170376068810&ssPageName=STRK:MEWAX:IT#ht_614wt_1165
what ford ignition system is this taken from been trying to work it out
RichardK
posted on 2/9/09 at 07:40 PM |
dunno but good value in bits to do a megajolt upgrade with.
I suspect as it is it'll run but at a static advance of 10 degrees (limp home) but am probably wrong.
Rich
Gallery updated 11/01/2011
blakep82
posted on 2/9/09 at 07:43 PM |
looks standard ford to me (don't know what model)
i think the coil pack has a ford logo on it
________________________
jonesier1
posted on 2/9/09 at 08:00 PM |
yep its ford.an early edis module from a fiesta or escort and at 10 degrees with out an ecu of sorts. Not a bad price though.
im in my own little world...its ok though they know me there
aaron bassett
posted on 2/9/09 at 08:09 PM |
will the edis 4 run standalone without a controller?
big_wasa
posted on 2/9/09 at 08:10 PM |
Its the ford esc as fitted to Fiesta's and escorts with the 1.1 and 1.3 carbed endura engine. Its like the edis4 but has a Map sensor and adjusts
advance on board.
Two wires to connect, live and earth and three plugs to connect. Coil, Cps and Temp.
There is also a vacuum connection to connect to the inlet manifold, This adjusts the advance according to load.
I’ve had loads of these along with the edis4's
The advance curve is not ideal for a modern 16v lump but will run a modest power zetec. Infact the Mondeo rod banger racers love them and due to this
they often fetch lots of dosh.
I can give you the wiring diagram if you need it.
cheers
[Edited on 2/9/09 by big_wasa]
![](/galpreviews/) ![](/gallery/)
big_wasa
posted on 2/9/09 at 08:13 PM |
The edis4 will run a rock steady 10 deg that is refured to as limp home mode.
What engine are you wanting to run it with ?
wiring dia
aaron bassett
posted on 2/9/09 at 08:14 PM |
yes please if you dont mind
aaron bassett
posted on 2/9/09 at 08:18 PM |
i was going to put on my 1.8 cvh for testing
big_wasa
posted on 2/9/09 at 08:23 PM |
Ideal on the cvh I ran one for months before selling to a guy on here who is still running it two years on.
That said I have the ignition set up for a 1.8l cvh if you need one.
The one in that link would have fetched near double if he had put Mondeo rod banger racer in the title.
aaron bassett
posted on 2/9/09 at 09:03 PM |
how much for mate
big_wasa
posted on 3/9/09 at 08:25 PM |
Just cover the postage and you can have them.
ive got the ecu / coil and loom but you will have to sort out the wiring your self, Ive just pulled it out of a sierra.
Ive binned the dizy cap and leads.
warren
