Alex.
posted on 9/9/09 at 09:47 PM |
Identifying a Pinto camshaft.
Hi Guys,
Is there any way to identify a camshaft for a Pinto?
It is obviously from a Pinto and has a splash of green paint on the shaft.
Alex.
deezee
posted on 9/9/09 at 10:01 PM |
Any aftermarket camshaft will have its details marked in the metal of the camshaft. Then you just google the spec
austin man
posted on 9/9/09 at 10:11 PM |
if its in a pinto its a pinto camshaft LOL
miikae
posted on 9/9/09 at 11:15 PM |
Piper put a letter and a number on the back end of the cam.
Mike
If it can be done it i will be done .
Alex.
posted on 10/9/09 at 07:29 AM |
I don't know if there are any markings on the end of the cam, I'll have a look when I receive it!
As the RS2000 Grp1 cam has a red spot of paint, I was wondering if the green spot of paint meant anything if it is a ford cam.
Alex.
jollygreengiant
posted on 10/9/09 at 08:52 AM |
Alex.
Ford used to I dentify the camshafts from 2 small nipples on the camshaft length about 10mm apart and about 2mm in height and 3mm in diameter each.
These were located between the lobes for either 1 & 2 cylinder or 3 & 4 ( I forget which from memory).
If both nipples were present then it was a 2.0 cam shaft, and if one had been ground off the it was a 1.6 camshaft.
I hope this helps ( mind you I am talking Mk3 & Mk4 cortina age here).
kj
posted on 11/9/09 at 06:53 AM |
I bought a replacement camshaft and it had green markings and it said on the box direct replacement for ford 2.0 O.H.C.
Marked up for RS2000.
Hope that helps
