cwollen
posted on 13/9/09 at 11:20 AM |
remote gearchange
My locost has a crossflow 1300gt engine and gearbox. Does anone know who can supply a remote chang as the gear leaver is too far forward obiously its
four speed
thanks
55ant
posted on 13/9/09 at 04:47 PM |
quick search only found one on the bay, but its not for your gear box! so this is pretty useless!
http://cgi.ebay.co.uk/Remote-gear-linkage-suit-Locost-Westfield-Kit-Car_W0QQitemZ270454252521QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash
=item3ef85463e9&_trksid=p3286.c0.m14
away from cars, now cycling and building TT bikes
panichat
posted on 13/9/09 at 05:14 PM |
Here we go...
Try Tiger Racing at www.tigerracing.com.
They do a budget one for £10.45 (although you'll need to fabricate the link arm).
Dave
Michael
posted on 13/9/09 at 08:21 PM |
From what i understand the only ones for Four speed leave the end plug off the Gearbox casing.
I made my own, by cutting down the original gearlever, but you have to remove reverse gate from the box then add a link under the transmission tunnel
top rail to another lever at the desired area.
My extra lever is an antiroll bar drop link, cut in half and M10 thread on the top for original ball.
Its not my own design, i saw a fellow Locost'r had done it.
arrow-engineering
posted on 21/9/09 at 09:03 PM |
extender
i did the same, used an old knackered ball joint and welded the gearstick that i had cut off to it and then made a link between that and what was left
of the original gearstick, was a very nice shift, you can design in some ratio and make a quickshift
