Author: Subject: 15x7 capri wheels
phelpsa
posted on 28/3/04 at 05:58 PM Reply With Quote
15x7 capri wheels
15x7 capri wheels, what do you think. Would they fit a Locost? They look in very good condition.
Adam
TPG
posted on 28/3/04 at 06:25 PM Reply With Quote
wheels
They will look good.Provided your arches are large enough they'll go on.But at 15" won't that give you poor off the line preformance?.Most H'climb stuff runs 13"s.Just a thought.
..Which was nice..
Tblue
posted on 28/3/04 at 07:52 PM Reply With Quote
15s shouldn't affect gearing that much, after all a 195/45/15 is only 4mm bigger in diameter than a 185/60/13 when new.
phelpsa
posted on 29/3/04 at 07:46 AM Reply With Quote
I am only looking for 15s as you can't run 13s on a sierra disc braked rear end and finding decent hillclimb tyres for 14s is tricky. What size tyres should I use
NS Dev
posted on 7/4/04 at 06:22 PM Reply With Quote
For a 7" rim you are looking at 205 to 225 width tyres, for competition you want to stick at the lower end of that range i.e. 205 or 215 max to give the sidewalls good support.
steve m
posted on 7/4/04 at 07:48 PM Reply With Quote
just for info I have 205/13 on my car
never again!!!
much to wide and in the wet f**ing lethal
anything over 60mph and you can turn the steering wheel without moving the car
phelpsa
posted on 8/4/04 at 08:11 AM Reply With Quote
You can get 195s on 7", westfield owners do it all the time on their superleggeras.
Adam
