pdm
posted on 13/9/09 at 07:14 PM |
Running in
Evening Everyone
I've done a search on running in but haven't been able to answer my question.
Assuming you've built an engine, how do you go about running in...
If you go for a first time start can you then leave it until driving to the IVA or is there a time limit on running in whereby once it's started
for the first time, you need to get it run in within a given time frame ? (Difficult with no registration, tax even if it's insured !!). I
guess what I'm after is is it ok to run in an engine by driving it say 20/30 mins at a time but over a longish period ?
For the IVA noise tests etc will the rev's be too high for an engine that isn't fully run in ? If so how have you gone about running
you're engine in ?
Another forum has suggested that you should put low quality oil in to start with for 100 miles to allow rings to seat then change and run too 500 and
change again - what's the consensus here ?
Paul
focijohn
posted on 13/9/09 at 07:40 PM |
A guy i work with built a 7 with a duratec (2.3) and after the big ends letting go hes been told to run it in on 15W/40 for a few hundred. Once thats
been done back to the "normal" oil. Hes got the advantage of it being mapped already.
I know this only covers one point but HTH a little.
John
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
philw
This is how i ran mine in
Must try harder
pdm
posted on 13/9/09 at 08:04 PM |
Excellent thanks.
Seems to back up what oil to use.
link is really useful too - looks like most of the seating would get done very early in the engine's life. All I need is a private road lol...
Thinking about it
posted on 13/9/09 at 08:06 PM |
Same problem here.
flak monkey
posted on 13/9/09 at 08:10 PM |
Run at fast idle (2500-3000rpm) for the first 20 mins to bed in the camshaft.
After that drive as you normally would using the whole rev range but avoid sustained high revs for the first 1000miles.
Sera
http://www.motosera.com
What engine is it...?
My freshly built Pinto was done like this...
Build up with supplied cam build-up lube and lots and lots of fresh engine oil. Fire up and run at 2 to 2.5 K rpm for around 20 mins to bed the new
cam shaft in and check for leaks (oil & water) and temp.
Let it cool, check valve clearances and plug condition.
Re-start periodically during the build for "private road" testing
First 250 miles limited to 4 k rpm, oil & filter change - then let it have the full beans on each and every gear change
posted on 13/9/09 at 09:39 PM |
Being a QA engineer and visiting a few plants around Europe I can say that running in is a load of horlicks...
Toyota at Burnaston have a dyno run on every car.. rev to the red line in every gear.. and engage reverse to make sure it cuts out...
Grimsby docks.. get down there and watch them load and unload the ships....
Jaguar, Brown Lane.. every car thrashed to death on the dyno...
You go and buy a brand new car from your dealer and its already been red lined and thrashed..
As nick says prepare well, build up correctly then red line all over!
wrigglypig
posted on 13/9/09 at 09:59 PM |
Built my pinto up 18 years ago I used a grease in the bores called Graphogen which the guy who bored the engine for me always used. I used a cheap oil
with no addatives for the first 300 miles and then changed it. I also had new big ends/mains/ camshaft / oil pump. The main thing I was advised was
not to labour the engine i.e. dont be in 5th at 1500 rpm and try and put your foot down.
I was advised that revving wasnt a problem. Its done 10,000 miles since has 65psi oil pressure when warm and happly revs to 5500 rpm without
drama.
Kev
mark chandler
posted on 13/9/09 at 10:31 PM |
The secrets full load for a few seconds at varying engine speeds, followed by no throttle.
The rings are forced into the bore walls with the pressure, when you let off oil then flushes the bores and lubricates ready for the next blast.
Race engines have a couple of hours on the dyno before being hammered, the second hour being power runs to the limit.
oldtimer
posted on 14/9/09 at 07:07 AM |
Loading up the rings really is the way, also use of actua; running in oil is good, then flush it out and use high quality oil after that.
paul the 6th
posted on 14/9/09 at 10:16 AM |
they had an article in one of the bike mags about running in bike engines and what the difference between running in oil & normal oil is...
If I remember rightly, running in oil isn't quite as 'lubricating' so the piston rings can bed into the cylinder walls more easily -
if there's too much lubrication then the rings won't seal as effectively.
As others have said, I've heard around 20 mins to get the engine warmed up and then when driving use the full rev range but not at constant revs
- so on a motorway or dual carriageway, fluctuate your speed and revs (safely)
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
pdm
posted on 14/9/09 at 11:24 AM |
Great thanks for all the info everyone
Marcus
posted on 14/9/09 at 11:48 AM |
Don't make the run to IVA the first run with new rings!!!
I did, and the plugs oiled up every 10 miles, I missed my SVA appointment and had to re-book.
Everything was fine for the second SVA run as the car had done an extra 50 miles or so...
Marcus
Because kits are for girls!!
