greenwood03
posted on 20/9/09 at 10:08 PM |
sierra rear beam/subframe weight
hi guys. got a tiger supercat which uses the sierra rear end, wondering if anyone knows the weight of that piece of kit and the realistic weight
saving possible by ditching that and fitting a de dion set up? the engine has been tuned as far as can realistically go, so now thinking about
chopping some weight - if its worthwile. done the usual google type search, but cant find any direct info on the weight of the existing unit......pub
'guesstimates' which are frankly not alot of help range from a weight saving of 20-50kg. ideally would be nice to know a bit more
precisely to decide whether worth the hassle....chrs mark g
snapper
posted on 20/9/09 at 10:14 PM |
If the Tiger uses the whole Sierra frame then you can't just ditch it as the Sierra back end has the swing arms as well as the frame.
Ditch the frame and you will need a way of attaching the diff, Some trailing arms and somewhere to hold them and the DeDion will add some weight.
Might be worth looking at the Haynes Roadster rear end as a pattern, possibly lighter and easier
I eat to survive
I drink to forget
austin man
posted on 20/9/09 at 10:25 PM |
as the man said its not that simple as the rear swinging arms attach to the beam, I have used the sierra arms at the rear but attached pick up points
to the chasis to carry the arms. there is quite a weight saving, if tou used the dedion you would save a few KGs no doubt, but if your going to that
expense why not go ull hog and modify for double wishbone suspension?
greenwood03
posted on 21/9/09 at 08:09 AM |
will check out the Haynes info...
dble wishbones - hadnt considered to the nth degree as had read that can be tricky to get set up correctly??
i know there was a tiger owner that did a form of de dion conversion on the same type of car, unfortunately the pics that he posted on the forum dont
give much detail and seems he's no longer an active member - otherwise would pick his brains a bit!
mark chandler
posted on 21/9/09 at 11:22 AM |
djtom is still active, he is fitting a dedion although it replaces a live axle.
You will need a good chop about, have a look here:
link
Antnicuk
posted on 21/9/09 at 12:40 PM |
how about speaking to Tiger, they maybe able to supply the bits you need together with the diagrams
Can you keep us posted as i have friend who has a Cat and wants to reduce some weight
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
greenwood03
posted on 21/9/09 at 03:37 PM |
mark: thx had forgotten that DJ Tom was doing his '6'......the guy i was thinking of did it to a Cat and actually had an email from him
this morning, although he's never had the car weighed since the conversion so am no further forward on that score, although will ping Tom a
message and quiz him........
