Author: Subject: Water tank in garden victorian house
tegwin
posted on 27/9/09 at 11:07 AM Reply With Quote
Ok... I think I have a question to which Locostbuilders will not be able to answer... but its worth a try..
We have a 2000 imp Gallon water tank in our garden (we live on a hill), so the tank is well above the level of the house!
The roof appears to be a brick arch, later reinforced with concrete, the walls are smooth concrete castings done in situ.
The main chamber is 2x2x2m but there is a smaller chamber off to one side, I cant see what is inside it but the entrance is about 1m high....
There is an old lead ball valve in the main chamber connected to a small bore pipe which I assume would have been connected to the old water main...
There are numerous springs along the line of hills at about the same height as the tank, although im not sure how spring water could get into the tank...
Does anyone know anything about tanks like this? Anyone know what its purpose might have been? 2000 gallons is big!
What are the chances that its just a header tank, rather than a spring collection tank?
www.verticalhorizonsmedia.tv
liam.mccaffrey
posted on 27/9/09 at 11:13 AM Reply With Quote
I am a qualified storage tank engineer/repairer but unfortunately it doesn't really cover this type of tank. I can try and give an informed opinion though.
Any pics?
[Edited on 27/9/09 by liam.mccaffrey]
Build Blog
Build Photo Album
bi22le
posted on 27/9/09 at 11:15 AM Reply With Quote
Well Tegwin you should never under estimate the power and knowledge of Locost members. You should however not listen to my knowledge of victorian spring water collection tanks as I know diddly squat!!!
Hope someone can help!!
Please read my ring story:
tegwin
posted on 27/9/09 at 11:26 AM Reply With Quote
Any pics?
An informed opinion would be a fantastic start Please, do go on
No photos at the moment, I tried to get some inside the tank this morning and you cant see much.... The water is very clear though!
The top of the tank is just a bog standard manhole cover.... I suspect falling in would be lethal!
liam.mccaffrey
posted on 27/9/09 at 12:37 PM Reply With Quote
is the tank buried entirely? is there vehicular access to it? If not you would assume that it would have been spring filled.
its not collecting water at the moment is it?
My gut feeling is that it is a mains header tank for collected spring water that has been retired and the inlet blocked off. You could pump some dyed water in and see where/if it emerges. We do this a lot at work to trace broken clay pipes runs
I personally wouldn't go down there, and would look at sewer access people or such like with proper BA gear and gas monitoring kit to go down and have a look and see whats in the small chamber.
Would love to see some pics, i love stuff like this!
Build Blog
Build Photo Album
tegwin
posted on 27/9/09 at 12:49 PM Reply With Quote
Yes, its burried entirely, the hillside is about 35 degrees, so its build back into the slope... interestingly, the base of the tank would be about where the bedrock starts.
There is no vehicular access to it, although the road above is only about 5 meters away and some 3 meters higher than the tank.
The modern water main for the house comes past the tank from the road above to the house...
The tank is currently about 85% full with a about 2-4" of sediment on the bottom (deeper where the manhole is for obvious reasons)
The outflow pipe is still clearly visible at the bottom of the water and is a perferated tube that comes about 1.5 feet into the bottom of the tank...
I have no reason to believe the water is going anywhere, appart from seeping out thanks to natural loss.
It would be nice to work out if/how the tank is being fed and then use the water either to turn a tiny turbine at the bottom of the garden, or use the water for a couple of small fountains.... (assuming its spring fed)...
I quite fancy draining the tank out and investigating further, but if the water is removed totaly from the tank, the pressure from the surrounding hillside might just cause the walls to rupture...It looks pretty sound, but its a risk that needs considering
Need to make/find an underwater camera and have a look in the side chamber without draining the water out....
Presumably if it were spring fed, there would be some form of sediment trap between the spring and the tank?
If the tank failed catastrobically, the resulting surge of water would proberably knock a hole in the house at the bottom of the slope
I dont think putting die in the water would help, I suspect there is little loss seeings as the outflow is blocked off... Perhaps I should excavate down slope from the tank a little and see how far the pipe goes...
As for entering the tank... once its drained of water, a simple candle test would proberably be ok
[Edited on 27/9/09 by tegwin]
mookaloid
posted on 27/9/09 at 01:13 PM Reply With Quote
How to Make Your Own Waterproof Camera Enclosure
blakep82
posted on 27/9/09 at 01:16 PM Reply With Quote
i'm starting to think you must live in some nuclear bunker type place!
________________________
tegwin
posted on 27/9/09 at 01:57 PM Reply With Quote
Haha... Yes, perhaps the tank is a mini bunker designed to supply fresh drinking water to the "garage" cough.. nuclear bunker...
I just found a load of leadgas piping under the floor in one of the bedrooms complete with nail holes where at some point over the last 150 years someone has put nails through it... thankfully its disconnected..... we also found some authentic cast bell pull linkages and cams under the floor... its a work of art!
posted on 27/9/09 at 01:59 PM Reply With Quote
Unless there's methane in there!
Know anyone with a Davy lamp (miner's lamp)? If the flame flares up, there's methane. If it goes out, there's CO2 or CO.
bob
posted on 28/9/09 at 10:38 AM Reply With Quote
Interesting
I have lived in my Victorian house for some 11 years now,we have a small extension to the rear of the house that was completed by previous owners in 1979. Locals i have met have told me a tank roughly the same size as yours had to be dug out where the footings were placed for the extension,the general opinion is water storage by locals.
Bore holes are very popular in the area with the water table in some gardens reachable with 12 to 15ft of scaffold pole and a hand pump.
bob
posted on 28/9/09 at 10:57 AM Reply With Quote
Maybe the victorians were ahead of the game re global warming,in australia and other warmer climes water preservation is paramount.
I know its not a diffinitive answer but google has failed me for once on this one.
Image deleted by owner
posted on 28/9/09 at 11:26 AM Reply With Quote
Thinking about it - my parents had a victorian house when I was a kid, and that had a large galvanized tank over the outside WC and coal store (2 separate places, I hasten to add!). I think it was original, as some other neighbours still had them. It was filled from one of the downpipes.
I'd guess that it served the same purpose as a water butt, as it certainly wasn't suitable for drinking! Or maybe they had different standards back then...
bob
posted on 28/9/09 at 11:54 AM Reply With Quote
Captured rainwater was used for flushing toilets in victorian houses and probably used in clothes washing tubs too,i'm thinking the underground tanks were literally just extra storage without using valuable overground space.
The Victorians did uttilise as much space as possible for allotment gardens.
posted on 28/9/09 at 12:01 PM Reply With Quote
That's probably it - the tank was over the outside loo, which also had the wash-house at its side!
