Author: Subject: FS complete pinto setup with bike carbs
jake_truck
posted on 27/9/09 at 07:07 PM Reply With Quote
FS : complete pinto setup with bike carbs
I have decided to swap to a zetec so my pinto is for sale. It is from my donor car, 1988 sierra 2.0i ghia. Included in the sale is everything needed to install except the starter motor;
zzr1100 carbs fitted to a homemade manifold,
MK stainless exhaust manifold,
full ignition system inc. dizzy, coil etc.
flywheel and quite new clutch,
properly shortened sump and oil pickup,
modified rocker cover,
alternator with modified bracket,
engine mounts,
correct fuel pump for the carbs,
the engine had covered approx 75000 miles when I took it from the sierra. I have done 600 miles with it. The head was removed before installing in my indy. The bores are in fantastic shape. A new head gasket, stretch bolts and valve stem oil seals were fitted, and the valves were reground. A new oil spraybar was also fitted. Every gasket has been replaced. The engine was compression tested and is well within ford tolerances.
I am asking £350 for the whole lot.
I'll sort some pics asap. U2U me if you are interested.
John
[Edited on 27/9/09 by jake_truck]
lotusmadandy
posted on 27/9/09 at 07:17 PM Reply With Quote
I can vouch for this engine package,it pulls strongly throughout the range with good power and sounds brilliant.
Someone is going to get a bargain.
