Author: Subject: sticking magnets to prop or driveshaft
dunk3
posted on 28/9/09 at 01:50 PM Reply With Quote
Hi all, whats the best stuff to use, when fixing the little round magnets to the prop shaft bolts or the drive shaft,so the sensor can pick up a signal for the speedo.
YQUSTA
posted on 28/9/09 at 01:54 PM Reply With Quote
I used araldite for mine. the non quick dry stuff.
I put a blob on then put the magnet in let it set a little then put a blob over the top.
not lost 1 yet and its been about 8 months.
shaun fulcrum
posted on 28/9/09 at 01:56 PM Reply With Quote
Not sure if it's the best stuff but I used Araldite. They haven't fallen off yet
Dangle_kt
posted on 28/9/09 at 02:16 PM Reply With Quote
Steve (Worx) did mine, he bonded them on - cant remember what with, but then put gaffer tape over them, one peice right round the prop - its worked very well at keeping them on. Seems a great idea.
When I whipped a couple off the other day I put the tape back on as seems to be doing a cracking job.
grazzledazzle
posted on 28/9/09 at 02:21 PM Reply With Quote
Isn't that going to put the prop out of balance?
whitestu
posted on 28/9/09 at 02:48 PM Reply With Quote
They are very small. I have one on mine and can't tell it's there.
I also used slow setting epoxy and some tape.
Mr Whippy
posted on 28/9/09 at 02:55 PM Reply With Quote
how about something like this? You could bolt it on with an extra long propshaft bolt. I'm sure a search on google will find a uk supplier.
UK supplier linky
[Edited on 28/9/09 by Mr Whippy]
twybrow
posted on 28/9/09 at 03:37 PM Reply With Quote
I used epoxy metal. Nothing moving them once well attached! They are still stuck despite my recent propshaft issues. I have just sent the magnets and epoxy metal to Dunning and Fairbank, who are going to bond new ones onto the new front prop section, before balancing it....
posted on 28/9/09 at 10:50 PM Reply With Quote
If they are near the ends they should not affect the balance. Glue them on then stretch a piece of cut down inner tube over them but you will have to take the prop off to do it.
Staple balls
posted on 29/9/09 at 12:29 AM Reply With Quote
That'd probably be a really bad idea, neodymium magnets are pretty fragile and rather brittle, I imagine bolting them on would break them.
matt_gsxr
posted on 2/10/09 at 09:44 PM Reply With Quote
I have a single magnet from a hard-disk drive that I trimmed down (think 3cm long 1cm wide).
Anyway I used a big jubilee clip to hold it onto the driveshaft at the inner tripod joint. Not particularly pretty, but no-one ever sees it and it has worked fine.
Also it was locost.
Agreed on using a magnet as a washer. A really elegant idea, but you won't be able to tighten it enough as the magnets material is really brittle.
Matt
DarrenW
posted on 4/10/09 at 10:04 PM Reply With Quote
Shallow hole and bond in.
