Author: Subject: twin 40's on pinto
luke_stephenson
posted on 29/9/09 at 04:34 PM Reply With Quote
twin 40's on pinto
Hi all, has or is anyone running a 2.0pinto on sidedraughts? what sort of power are you getting?
cheers
RichardK
posted on 29/9/09 at 04:40 PM Reply With Quote
My opinion, don't bother, bike carbs all the way, but thats not the question you asked so I'll shut up now
Rich
Gallery updated 11/01/2011
flak monkey
posted on 29/9/09 at 04:46 PM Reply With Quote
I ran mine on both 40s and 45s DCOE's
The 45 unlocked some more power especially up the top end, but also reduced the fuel consumption by approx 5mpg to an average of 22mpg.
Look a lot better than bike carbs (which I still dont think are as good as a properly set up pair of side draughts) but then I am biased
I then switched to injection on 36mm throttle bodies and the difference was noticable. No effect on power, but much better low down driveability.
Going by the on the road performance (and what it could keep up with 2 up) it was putting out somewhere around 160-170bhp.
Sera
http://www.motosera.com
tomgregory2000
posted on 29/9/09 at 06:39 PM Reply With Quote
i think bike carbs are no good as well, i have 45 dhla's on my red top, they look fantastic, you can pick up a set of twin 40's and an inlet manifold for a couple of hundred £ and loads of people have done it so there is plenty of info on which jets you need
bike carbs £30-£60
inlet manifold free(make it yourself) to £160
dyno jet kit £50 ish
rolling road set up £100 ish
snapper
posted on 29/9/09 at 07:00 PM Reply With Quote
More stories of people having problems with bike carbs.
I have had problems with the same set of carbs on 2 engines so am swapping to DCOE's. Have a set of 40's but most people say 45's for a 2.1 Pinto with big valve head and 300 duration cam.
The jets are interchangeable between 40's and 45's but not the venturies so will build up the 40's and swap when i have the cash for 45's.
I eat to survive
I drink to forget
Keith Weiland
posted on 29/9/09 at 08:05 PM Reply With Quote
Luke,
you have a U2U
jacko
posted on 29/9/09 at 08:09 PM Reply With Quote
Bike carb are the Best 30mpg set them up and forget them unlike webbers
[Edited on 29/9/09 by jacko]
graememk
posted on 29/9/09 at 09:55 PM Reply With Quote
can you really get 170 bhp from a pinto ?
anyway dont waste your cash get yourself a zetec cheap as chips power, pinto is old hat history, zetec is good power no mods needed.
MautoK
posted on 29/9/09 at 10:15 PM Reply With Quote
SUs work for me:
Nearside
Nearside
Andy D
posted on 30/9/09 at 06:04 AM Reply With Quote
2.1 Pinto on twin Weber 45s. A properly set up pair of webers don't go "out of tune" Mine haven't been touched for at least a couple of years.
I've said it before and I'll say it again, the biggest problem with webers is finding someone who really knows how to set them up.
whitestu
posted on 30/9/09 at 07:59 AM Reply With Quote
Depending on the carbs you choose bike carbs can be very cheap and effective.
Mine cost £30 for the carbs, £10 to make the manifold [no welding needed], plus the cost of an air filter.
They work really well and drivability is excellent. I set my own up with an AFR meter so it probably could be better, but goes really well and does about 38mpg.
rallyingden
posted on 30/9/09 at 08:06 AM Reply With Quote
Yeah but you cant beat the sound of a well tuned set of 40's trying to suck anything that gets in their way
Mr Whippy
posted on 30/9/09 at 09:01 AM Reply With Quote
I have a pair of 40's for my pinto but to get the jets that are right for engine will cost £219...that's quite a lot
FASTdan
posted on 30/9/09 at 10:22 AM Reply With Quote
ours recently did 110bhp@wheels @5800rpm, so roughly 130bhp flywheel. thats a totally standard 2.0 pinto (injection head), dellorto 40's and MK manifold running on the stock transit ignition.
