Author: Subject: Viento rear wheel width?
tomgregory2000
posted on 3/10/09 at 01:45 PM Reply With Quote
Does anybody know if a 9" wide rim with a 255/40/17 tyre fit inside the huge wheelarches?
kenton
posted on 3/10/09 at 01:54 PM Reply With Quote
Yes, thats what i have.
kenton
tomgregory2000
posted on 3/10/09 at 02:00 PM Reply With Quote
great thanks.
Going to need something wider than my 205 at present when i fit the new engine
speedyxjs
posted on 3/10/09 at 03:05 PM Reply With Quote
Isnt the new engine fitted?
huge supercharger
huge supercharger
tomgregory2000
posted on 3/10/09 at 03:08 PM Reply With Quote
yeh i had a little problem with seeing where i was going
Paul (Notts)
posted on 3/10/09 at 03:39 PM Reply With Quote
I am running 235 on an 8 inch rear rim with 20mm spacers -
If I ever get new rear tyres will go for 255
all depends on getting the correct of set to start with.
Paul
Jackaroo
posted on 3/10/09 at 06:22 PM Reply With Quote
I had the two rear rims widened from 7" to 8 1/2" and fitted 235/45/ZR17 tyres. The offset is ET38, could'nt find a lower offset at the time I bought the rims. I will definitely also go for 255/40/17 the next time I chage tyres and I also want to have 10 mm spacers manufactured so that they can fill a bit more towards the outsude, I guess the tyre outer wall will then be another inch closer towards the outside which is what I originally was hoping for.
Gerrie
NeilP
posted on 3/10/09 at 09:59 PM Reply With Quote
Running the same as you intent to fit with 25mm spacers...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
hector
posted on 4/10/09 at 01:11 PM Reply With Quote
Hi all
I bought 15" x 9" (rears) compomotives for my viento with ZERO offset and fitted 20mm spacers also and they fill the arch nicely, only have 225's on themFront are et38 on 7" rims
wilkingj
posted on 4/10/09 at 01:30 PM Reply With Quote
I have 8" rears with 235 tyres, and a 22mm offset and 15mm hubcentric spacers.
In hindsight, should have gone 9 or 10" rears with 255 or 265 tyres.
I had my wheels made, and still got it wrong! However, I was erring on the side of caution. At least they fit under the wheel arches and are level with the outside edge of the wheel arch.
There is a lot of room under Viento rear arches. They were made big to keep the aspect ration of the rear view correct.
Otherwise it would have been a wide body with narrow arches, and would not look right.
Best Regards
Geoff
http://www.v8viento.co.uk
bj928
posted on 24/10/09 at 01:34 AM Reply With Quote
I'm running 10" 295 under the rear and they fit just fine
posted on 24/10/09 at 08:47 AM Reply With Quote
Welcome back big boy ! How's it going?
bj928
posted on 24/10/09 at 09:25 AM Reply With Quote
Had a slight delay, had to do 60 days in prison for not paying council tax, silly me!!!!!!, but now i'm out, car should be moved to new workshop next week so i can get on it over the winter.
