Author: Subject: changing information output to monitor
mads
posted on 5/10/09 at 10:40 AM Reply With Quote
I am hoping someone can give me some advice for the following problem:
I want to output a powerpoint slide (only one, not a slideshow) to a monitor in a different. Not a problem.
However, on this slide I want to be able to change 2 details at various points during the day. These are a name and an associated number with the name. This will be done by the user who is taking over.
Is there a way I can use powerpoint to have a backend where the user can change the name/number and this will then update the page being displayed in the other room?
Or is there another way of doing this? Maybe php? Anyone able to code this for me? Or an Access database to hold details of the users/numbers and more can be added?
Thank you in advance.
mads
[Edited on 5/10/09 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
blakep82
posted on 5/10/09 at 10:45 AM Reply With Quote
are these people going to be on, in a certain order?
make several slides, in the right order, then all the person has to do is click the mouse once, next slide shows their name
________________________
locost@mintynet.com
posted on 5/10/09 at 11:10 AM Reply With Quote
You could try using a web page, working from a database, configured with auto refresh.. You would need to run iexplore -k to run internet explorer without the menu bars at the top..
If you dont want the page on the main screen, use ALT and SPACE, then select move and use the arrow keys to shift to the second screen.
Hope that helps
Ian
[Edited on 5/10/09 by locost@mintynet.com]
mads
posted on 5/10/09 at 12:28 PM Reply With Quote
blake - no set rota of people so cant do a certain order of slides.
Ian - I am thinking that that may be the route I end up going down.
Anyone got any other suggestions?
