Author: Subject: 51mm - 45mm filler hose?
speedyxjs
posted on 6/10/09 at 01:27 PM Reply With Quote
Is there such a thing?
I need to connect my tank to my filler cap.
myeates
posted on 6/10/09 at 01:35 PM Reply With Quote
had the same problem with mine endned up buying a length of 51mm tube and the getting an adapter to take it down to 45mm from car builder solutions looked everywhere couldnt find the stuff that was the right one
James
posted on 6/10/09 at 02:38 PM Reply With Quote
I made one out of a couple of bits of appropriate length 1.6(?)mm strip bent into tubes the correct diameter... then welded together.
Bloody thing's never stopped leaking since!
But I'm sure if more time were taken it could be done better!!! Mine was done about 5mins before SVA IIRC!
James
russbost
posted on 6/10/09 at 08:19 PM Reply With Quote
silicon hoses reducer??? That's what I used
