Author: Subject: Diff output / drive shafts
Raymond Y
posted on 7/10/09 at 07:52 PM Reply With Quote
Hi, has anyone tried fitting flanged / bolted (type B) output shaft to a push in drive shaft (type A) diff.
Raymond
turbodisplay
posted on 8/10/09 at 06:24 AM Reply With Quote
If it is a LSD unit then def no as the push in shafts are different lenths, if no LSD then i think it should work, someone will be able to confirm.
Darren
