Author: Subject: Left over bits - Xflow
Richard Jenkins
posted on 3/4/04 at 05:18 PM Reply With Quote
I'm rebuilding my 1300 Xflow and in the bottom end gasket set, in the same plastic bag as the sump end seals, were an O ring and a plastic washer. I couldn't see anything in the Haynes book about them, so in time honoured tradition I ignored them
Anyone know if this was a bad idea and I'm now looking at taking the sump back off to fit these mystery bits?
cheers
RJ
posted on 3/4/04 at 05:28 PM Reply With Quote
Plastic washer may be sump plug sealing washer. as for 'o' ring could it be for the oil pick up pipe to block seal ?? hope this is of help. Rusty
Tblue
posted on 3/4/04 at 05:46 PM Reply With Quote
The o-ring is probably for the dizzy stem.
Richard Jenkins
posted on 4/4/04 at 11:22 AM Reply With Quote
O ring is for dizzy (ta Tblue).
Don't think the washer is for sump plug tho', should be copper I think.
Hornet
posted on 5/4/04 at 07:25 AM Reply With Quote
Washer could be either blck or white... for sump. Have seen plastic and steel.... hey its a xflow... built to last
