Author: Subject: Torx Sierra diff bolts
Irony
posted on 13/10/09 at 02:45 PM Reply With Quote
Quick question as I have search to no avail.
What is the size of the Torx drive bolts on the sierra 7.5 inch diff?
Is it a Torx or a star drive or are they the same thing?
I have heard its a t50 torx bit. True or False?
purdy
posted on 13/10/09 at 02:59 PM Reply With Quote
i think its a 45 but not a 100% sure, I got mine direct from ford, they arnt expencive.
if they have seized up cut the heads off with grinder pull the cv joint off then remove the remaining studs with pair of stilly's then replace with new....
regards
Mark
Colnago_Man
posted on 13/10/09 at 03:11 PM Reply With Quote
Someone post this link very recently.
http://www.mc2racing.com/tech/20081104a/index.html
Might help.
Irony
posted on 13/10/09 at 03:14 PM Reply With Quote
Might help.
Yeah that is where I got the t50 from. Doesn't seem to mention the bolts that connect the drive shafts to the diff. (unless my print out has missed some bits off, which is not unlikely)
adrianreeve
posted on 13/10/09 at 04:05 PM Reply With Quote
It's a T45.
Adrian
posted on 13/10/09 at 05:48 PM Reply With Quote
I've replaced mine with 12.9 hex bolts.
cd.thomson
posted on 13/10/09 at 07:09 PM Reply With Quote
2nded, so much easier to work with
Craig
NS Dev
posted on 14/11/09 at 08:17 PM Reply With Quote
3rd'ed!
Cut off the old ones, its not worth knackering a torx bit (and it WILL!). just cut the heads off and replace them with M8 x 50 normal capheads
