Author: Subject: SETTING UP SUSPENSION
dave107
posted on 20/10/09 at 09:27 AM Reply With Quote
Help
When setting up the suspension ie: ride height, tracking, camber, toe in/out and all other settings is there a correct order to follow so setting already done don't get messed up.
Dave107
Bluemoon
posted on 20/10/09 at 09:39 AM Reply With Quote
It's iterative, but ride hight and corner weights would be where I would start.. Just remeber to set the ride heights with driver and passenger (or dummy weights)....
Dan
[Edited on 20/10/09 by Bluemoon]
MK9R
posted on 20/10/09 at 10:10 AM Reply With Quote
What he said. You will have to keep going round and round making smaller and smaller adjustments as they all effect each other. Something change other thing more than others, for example changing the camber on my fury effects the toe more than the toe effects the camber, so you will learn which order to do things in so changes to one thing minimises changes on another.
What a rambling!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Bluemoon
posted on 20/10/09 at 10:38 AM Reply With Quote
^^^ Don't worry about the rambling, it's much like setting the car up; takes ages (take your time, and don't expect to do it in less than a weekend if your doing it using spirit levels and string, and a bit of trig!!).. Also write down all the settings once done so you can use this as a baseline for further changes..
Dan
PumaWestie
posted on 20/10/09 at 10:52 AM Reply With Quote
Ride heights
Corner weights
Camber
Tracking
Then recheck
dave107
posted on 20/10/09 at 11:34 AM Reply With Quote
Thank guys.
When doing corner weights do you loosen wishbone bolts and shocks, think i read that somewhere.
Dave107
hampshe
posted on 20/10/09 at 11:47 AM Reply With Quote
Before all these things ensure the floor is dead level (at least under all the wheels)
antonio
posted on 20/10/09 at 12:31 PM Reply With Quote
Originally posted by dave107
Thank guys.
Dave107
no need IMO, unless your car is brand new with 0 miles.
cheers
MakeEverything
posted on 20/10/09 at 12:32 PM Reply With Quote
Thank guys.
Dave107
The reason for this is to minimise Stiction at the bushes, preventing the wishbone from travelling without pressure.
Kindest Regards,
Richard.
PumaWestie
posted on 20/10/09 at 01:19 PM Reply With Quote
Of course if you have rose joints there is no need for this. However, I would also disconenct any anti roll bars as well and reconnect them when finished but do not forget to adjust the drop links to suit the normal loaded weight of the car to eliminate preload in them
