Mark Allanson
posted on 6/4/04 at 09:57 PM |
Fuel tank straps
I need to anchor my fuel tank to the chassis, I know that steel straps are normally used. How are these fastened and tensioned at the rear?
I have welded in lugs at the front for bolts welded to the straps to be tensioned with a nut from underneath
![](/galpreviews/a99204-Inner Rear Panel.jpg) ![Rescued attachment Inner Rear Panel.jpg](/gallery/a99204-Inner Rear Panel.jpg) Rescued attachment Inner Rear Panel.jpg
posted on 7/4/04 at 05:56 AM |
Use the M6 "J" bolts use for retaining sheets of roofing
Hornet
posted on 7/4/04 at 06:58 AM |
I used rivnuts into rear of chassis Mark (5mm) and brackets at front same as you.
Tank is solid and will not move.
Tigger
posted on 10/4/04 at 10:07 AM |
Another method is to bolt them down at the front but at the rear, use a strong pair of springs (one each side).
This method is used on the older Westfields.
Jasper
posted on 10/4/04 at 12:03 PM |
Much easier to do b4 rear ali is in place ![](/images//smilies/bigsmile.gif)
Mark Allanson
posted on 10/4/04 at 12:14 PM |
Thanks for that one, Jasper
M@Triton
posted on 10/4/04 at 12:20 PM |
Put mounting lugs underneath the tank so fixing and removing is less of a problem once your panels are in place.
posted on 15/4/04 at 03:07 PM |
Welding brackets on is likely to cause fatigue cracks in the tank, the tradditional way to mount tanks is steel straps right around the tank cushioned
by rubber to prevent chaffing. The straps are tensioned by thredeaded tensioners -- usually a long bolt with a hook at one end.
Tanks get quite heavy when full --- even if only 5 gallon locost sized, all that fuel sloshes around as the tank wall material is quite thin it
causes tank wall to flex quite a lot hence fatigue cracks at seams and any welded brackets.
[Edited on 15/4/04 by britishtrident]
James
posted on 18/4/04 at 10:26 PM |
So then Mark, you've had a week- what'd you come up with?
You can tell what bit I'm doing right now can't you... ?
James
Mark Allanson
posted on 18/4/04 at 10:38 PM |
I'm dealing with the other end at the moment, I am going to make 3mm small plates which I will rivnut to the inside of the rear tube and weld
some threaded bar to this. The straps will be 2mmx 30mm stainless, with a 90 degree at both ends with a hole in them, add nuts and tighten
James
posted on 19/4/04 at 10:50 AM |
Would 2mm ali straps be ok? Or not strong enough? Only ask as I have some kicking around and it'll be easier to bend than steel!
James
posted on 19/4/04 at 11:08 AM |
Really better in to be steel aluminium alloy has no real yield point. You could however could you use a bit of aluminium alloy windscreen style
channel or angle or even stel RHS across the top and very long threaded rods.
