Aled_g
posted on 27/10/09 at 03:48 PM |
Ride Height
Does anyone know what the best ride height would be i.e. for a Double Wishbone IRS setup on the rear. Looking for slight negative camber
And if anyone knows roughly the overall vehicle weight of a Locost that would be great, cheers.
liam.mccaffrey
posted on 27/10/09 at 03:57 PM |
Where about are you? I'm down west
They car vary wildly from 450kg on the super slim side right up to around 750kg.
what engine/box combo you thinking of? that will give a better idea for a weight target?
Build Blog
Build Photo Album
posted on 27/10/09 at 04:02 PM |
Mine weighed in at 450kg with me in it, will have gone up a bit since then though...
Bluemoon
posted on 27/10/09 at 04:04 PM |
Most MK indys with IRS seem to run around 135mm at rear..
This is a can of worms though, you design the suspension for a particular ride height wheel/tire combination etc etc...
Have you a copy of Alan Stanforths book?? He has a "sting computer" for working diffrent designs out..
Dan
liam.mccaffrey
posted on 27/10/09 at 04:10 PM |
Staniforths Race and Rally car Source book is very good
Build Blog
Build Photo Album
StrikerChris
posted on 27/10/09 at 05:01 PM |
mine weight about 620kg,chassis measures about 110mm front and back.sumps lower and its only bottomed out once so far,on abit of b road with plenty of
guages out of it!speed bumps are best avoided tho
speedyxjs
posted on 27/10/09 at 07:31 PM |
If you want a more accurate weight, you will need to give more info. bec/cec, engine
