Author: Subject: wheel spacers
gy351100
posted on 30/10/09 at 04:36 PM Reply With Quote
wheel spacers
Hi all
I have a pair of 19mm wheel spacers to fit an English axle.
The problem I have is there is not enough space between the hub and the brake back plate to fit the extended studs.
It seems i would have to withdraw the hub/drive shaft by about 20mm.
Has anyone had this problem before.
Keith
austin man
posted on 30/10/09 at 04:42 PM Reply With Quote
ideally remove the hub as they need to be driven home onto the splines
blakep82
posted on 30/10/09 at 04:51 PM Reply With Quote
they can also be 'pulled through' with washers and an old wheel nut can't they?
but yeah, the shaft really ought to come out in any case
________________________
posted on 31/10/09 at 09:21 AM Reply With Quote
I've had ones so tight that tightening them as much as I dare still wouldn't fully seat the splined section, they should ideally be pressed in.
