Author: Subject: Fiat twin cam to type 9
Doc
posted on 7/4/04 at 08:59 PM Reply With Quote
Are there adaptor plates available to fit a 2l fiat twin cam engine to a ford type 9 gearbox?
Mark Allanson
posted on 7/4/04 at 09:04 PM Reply With Quote
I think it was Nick Davidson who tried for ages to do it, try a search. The main problem is the starter which is on the wrong side, so a completely redesigned bellhousing would probaby be needed. Nothing is impossible, just expensive!!
Noodle
posted on 7/4/04 at 09:43 PM Reply With Quote
Guy Croft shows an example of an adapter plate in "Modifying and Tuning Fiat/Lancia Twin Cam Engines". That book's probably nearly 10 years old now though.
http://www.guy-croft.com/
Neil.
Your sort make me sick
posted on 7/4/04 at 11:04 PM Reply With Quote
I think you can use a Lada gearbox if you don't get anywhere with the adaptor idea. You might have to go to Russia to find one though
NS Dev
posted on 7/4/04 at 11:07 PM Reply With Quote
Yep, Lada Riva/Niva gearbox is a copy of the old Fiat one
theconrodkid
posted on 8/4/04 at 06:57 AM Reply With Quote
had a couple of ladas,boxes are made of chocolate tho
who cares who wins
pass the pork pies
posted on 8/4/04 at 07:29 AM Reply With Quote
Alfa used the Fiat 5 speed on the live axle RWD cars
James
posted on 8/4/04 at 09:34 AM Reply With Quote
Has no one tried modifiying the bellhousing themselves? Cutting out the starter mount and moving it to the other side can't be that hard I'd have thought!
They're cast steel aren't they? So should be weldable.
Or maybe that's just a rubbish idea!
James
timf
posted on 8/4/04 at 10:00 AM Reply With Quote
James
james have a look at a rs2000 bellhousing
in the rally design website
James
posted on 8/4/04 at 11:07 AM Reply With Quote
Looked all over that poxy website of theirs- can't find it.
Any chance of better directions!
James
timf
posted on 8/4/04 at 12:34 PM Reply With Quote
gear leavers bottom of page
AvonBelgium
posted on 9/4/04 at 07:59 AM Reply With Quote
A box from a Fiat 124 / 131 /132 will fit.
There are two versions, the later one is match stronger. These boxes won't fit the 16 valve engines with balance axes.
posted on 9/4/04 at 09:27 AM Reply With Quote
Trying to find one in the U.K. is like looking for the end of the rainbow. I looked for one for ages.
Mark Allanson
posted on 9/4/04 at 06:37 PM Reply With Quote
The last time Alfa made a live axle car was about the same time the Ford were thinking about introducing the Cortina Mk1.
Fiat and Alfa were, at this time, bitter rivals and Alfa NEVER used a Fiat gear box until they became part of Fiat
Doc
posted on 9/4/04 at 10:16 PM Reply With Quote
Thanks for the replies.
A fiat box isn't a problem as there are currently 2 in the garage. The problem is these parts came out of scrap cars and were intended to go in an existing car so no reg documents were acquired. To avoid a q plate it would be easy to acquire a pinto sierra, get through the SVA and then swap the engine for the superior fiat twin cam (flame suit on ). I guess the box will have to get swapped as well.
Mark Allanson
posted on 9/4/04 at 10:23 PM Reply With Quote
I am using a Pinto 2.0i, but I agree, the Fiat TC is a real jewel of an engine. I wanted to use a tuned F.I.R.E engine to begin with, but the box problem lead me to the Pinto for an easy (did I really say that!) life
