New Topic New Reply
Author: Subject: Fuel tank
EasyJimbo
posted on 22/11/09 at 05:10 PM Reply With Quote
Fuel tank
Picked up my fuel tank from MK today at the exeter show, and they didnt have the straps they usually sell to fix them on with. I asked about this and they said they dont do them anymore and I should just bond the tank onto the brackets of the chassis. Does that sound ok, I would have though the straps were a must?
thanks
J
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
big_wasa
posted on 22/11/09 at 05:15 PM Reply With Quote
No
Just make some up out of 25mm wide 16swg steel strip.
[Edited on 22/11/09 by big_wasa]
jacko
posted on 22/11/09 at 05:18 PM Reply With Quote
If it was me i would put straps on you dont know if you may need to remove it one day
designer
posted on 22/11/09 at 10:32 PM Reply With Quote
Use straps, always. Fuel tanks are heavy when full and I have seen welded mounting tabs crack through fatigue.
posted on 8/12/09 at 08:14 AM Reply With Quote
Always use either plastic coated straps or plain straps with rubber insertion between the tank and metal surfaces to allow some movement but prevent chaffing.
LPG conversion parts suppliers sell suitable plastic coated straps in kit form up to 1500mm long.
http://www.tinleytech.co.uk/acatalog/Tank_Straps_and_Brackets.html
[Edited on 8/12/09 by britishtrident]
New Topic New Reply
