Author: Subject: Gear Box Mount
tr
posted on 12/4/04 at 09:01 PM Reply With Quote
Gear Box Mount
Does anyone know what thread bolt I need to fit in the mount point cast in the bottom of a Type 9 G'Box? Seems a bit bigger and M10 and a bit smaller than M12... (M11 maybe ) but I think it might be old money. I had to grind through the original one and it seems to have got lost since...
Tom
Staple balls
posted on 12/4/04 at 09:05 PM Reply With Quote
sounds like they might be 7/16 unf, same as seatbelts
Northy
posted on 12/4/04 at 09:18 PM Reply With Quote
It M12 I think from memory. Deffo metric. Its probably full of crap!
Graham
Markp
posted on 12/4/04 at 09:30 PM Reply With Quote
As Northy said,
I too remember it being m12, it's not imperial.
Mark.
Mark Allanson
posted on 12/4/04 at 09:34 PM Reply With Quote
I've just measured mine, its M12x2mm offset, 39mm of thread from the upper face of the elongated hex section, 19mmAF.. This has a M10x1.75mm threaded section in the base, which is 24mm deep (I haven't a clue why it is there!)
MikeR
posted on 12/4/04 at 09:54 PM Reply With Quote
The threaded section in the base is to allow a bar to be taken from the mount to support the sierra exhaust.
Now is it normal or left hand thread ? (cause mine won't shift from my box )
Mark Allanson
posted on 12/4/04 at 10:01 PM Reply With Quote
They are both normal thread, the threads have probably eaten into the ally of the box, a little heat and a good welt with a ballpein should do it
tr
posted on 12/4/04 at 10:22 PM Reply With Quote
Blimey lads that was quick going!
I'll go and give it another try tomorrow with an M12. Now I think about it It's been painted so the thread could be full of crap.
Thanks again
Tom
