New Topic New Reply
Author: Subject: Lotus/Westfield XI
RobLyon
posted on 12/12/09 at 09:02 PM Reply With Quote
Lotus/Westfield XI
Firstly my apologies if this is the wrong section
I've fallen in love with the above car to the point where it keeps me up at night trying to figure out how I can get one. AFAIK westfield have stopped manufacturing the kits? I cannot afford the £15k+ they (probably quite rightly) command if/when they do come up for sale so how else can I get my mits on one?
There's a video on youtube of some guy scratch building his but I wouldn't know where to start. I have considered buying an older westfield 7 and trying to modifiy it to suit but im not sure how similar/compatible the chassis' are? Theres the GTS challenger plans but from what i've read Darren's reputation isn't the best and i've read of the troubles with the monoshock rear and the wishbones hitting the shock body
I cannot weld but am willing to learn, however I've looked into night classes but these are aimed at becoming qualified which probably exceeds my requirements? How else can I learn?
I am fairly competant with solid works and sheet metal design and have access to a clarke mig welder so maybe some small practice projects?
The other concerns are sourcing the bodywork and i'd like an alternative engine to the 1.3 A series. I've been thinking a RX8 rotary would suit quite well but i'm not sure if it would fit under the slimline bodywork?
My apologies if this comes across as a drunken ramble (which it is) but any thoughts/help would be very much appreciated,
Regards,
Rob
stevebubs
posted on 12/12/09 at 09:05 PM Reply With Quote
STill available....
http://www.westfield-sportscars.co.uk/XI.html
RobLyon
posted on 12/12/09 at 09:18 PM Reply With Quote
I read here that they're only making 50 and I read on WSCC that the 49th was sold on 15/6/2006 so just assumed they've all gone. I've asked for the info/pricing pack and not received anything so assumed they're finished with the XI?
Trev D
posted on 12/12/09 at 10:37 PM Reply With Quote
Hi Rob i was going to biuld a X1 but i have sold the project on which was a half biult chasis chasis jig and plans .I was going to make an all ally body but there is a guy called Mike Brotherwood he is a Lotus specialist reproducing the front and back in fiberglass. I still have a set of plans for the chasis hope this is some help. ATB Trev.
RobLyon
posted on 12/12/09 at 11:42 PM Reply With Quote
Hi Trev,
Do you still have copies of the plans and also contact details for Mike? Out of curiosity how much is a part built kit worth?
Thanks,
Rob
Chippy
posted on 12/12/09 at 11:44 PM Reply With Quote
Sorry to high jack. Trev how is the hard top coming, you havn't put any new pic's in for a while?? Cheers Ray
AdamR
posted on 13/12/09 at 12:48 AM Reply With Quote
Rob, have you seen the GTS Challenger?
cs3tcr
posted on 13/12/09 at 01:34 AM Reply With Quote
I've just finished my XI replica and am more than willing to help out with any info in regards to building it.
Heres a link to my build log:
http://www.locostusa.com/forums/viewtopic.php?f=36&t=3137
mark chandler
posted on 13/12/09 at 01:58 AM Reply With Quote
That looks fantastic, wish I had the skills... need more practice
x_flow57
posted on 13/12/09 at 09:52 AM Reply With Quote
If you've fallen in love with the 11 I think you would be dissapointed with the Challenger as it really is a 15/11 lookalike rather than a replica.
More Challenger Pics.
Outside Norwich SVA Centre
We parked next to a Westfield and it's tiny in comparison but Tim's Challenger is a lot quicker as the Westfield is only based on the "A" series engine.
Don't know where you are but if you are local(ish) you are welcome to come and have a look, sorry but I'm busy at wk till after Xmas tho.
Nick
contaminated
posted on 13/12/09 at 10:45 AM Reply With Quote
Personally I really like the Tiger ERA 30.
http://www.tigerracing.co.uk/era-30.php
RobLyon
posted on 13/12/09 at 12:59 PM Reply With Quote
Hey Rod,
I've just finished reading your build diary and its your videos on youtube that I mentioned. The car looks amazing and I wish I had a 1/100th of your skills
Nick: Thanks for the offer but unfortunately im a bit too far away (Hull). From looking around yours is the second one that i've seen finished. I also note you've ditched the monoshock infavour of the DeDion. I read there were concearns over shock body/wishbone interference on the blue car has this been resolved?
Contaminated: Yea the ERA 30 is really nice too but its £18k+vat for the kit?
[Edited on 13/12/09 by RobLyon]
x_flow57
posted on 13/12/09 at 05:41 PM Reply With Quote
I believe ours was the 2nd built and put through SVA.
The rear is now supplied with a DeDion set up and I have to say it appears to work very well, the springs are close on the ft. but don't touch even with them wound right up to get the head lamps high enough for SVA.
All in all it was a fairly straight forward build except the body which, amongst other things, was at least 2" wider on the N/S than the other & needed the arches "stretching” to clear the wheels.
Nick
New Topic New Reply
