Author: Subject: Wiper linkage w/motor
Vetvrach
posted on 13/12/09 at 07:44 AM Reply With Quote
good afternoon friends
tell from what car you set a wiper linkage w/motor? but my car LHD.
theconrodkid
posted on 13/12/09 at 08:07 AM Reply With Quote
usually a mini,thats a real (old stylie) mini not the BMW cheap copy type
who cares who wins
pass the pork pies
turbodisplay
posted on 13/12/09 at 08:35 AM Reply With Quote
Citroen Ax wiper motor is a good type.
It is a single wiper, so i fitted a linkage where the wiper is ment to go, to drive two seperate wiper linkages.
Thhe brilliant thing is the mechanism is smooth, unlike a crank drive of most wipers.
Darren
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 13/12/09 at 10:39 AM Reply With Quote
mines from a mini, very simple and so easy to modify to suit any needs
posted on 13/12/09 at 11:10 AM Reply With Quote
Apart from the wiring, which is - er - unique!
It is an easy mechanism, and the novel 'wiper park' wiring is not too hard to overcome.
posted on 13/12/09 at 01:19 PM Reply With Quote
There is a wiring diagram for the Mini/Lucas wiper motor on the Robin Hood site IIRC? Biggest problem I had was getting hold of some new terminals to fit the connector block
Canada EH!
posted on 13/12/09 at 04:05 PM Reply With Quote
MGB or any BMC product sold in North America in the 50's and 60's all LHD
Vetvrach
posted on 13/12/09 at 08:04 PM Reply With Quote
where in Russia I will find such detail)))
Steve @ sVc
posted on 15/12/09 at 12:00 PM Reply With Quote
Try our web site
www.s-v-c.co.uk look in "other products" - "wipers" we supply world-wide
Regards
Steve @ sVc
Vetvrach
posted on 16/12/09 at 07:53 AM Reply With Quote
Originally posted by Steve @ sVc
Try our web site
Regards
Steve @ sVc
very interesting complete set, but very expensive(((
I will accumulate money...
Vetvrach
posted on 16/12/09 at 08:09 AM Reply With Quote
Try our web site
Regards
Steve @ sVc
http://www.s-v-c.co.uk/prod/wiper-kit.html
This kit for RHD of LHD kitcar?
scudderfish
posted on 16/12/09 at 08:43 AM Reply With Quote
It should do both depending on which way round you put it all together.
Steve @ sVc
posted on 16/12/09 at 04:11 PM Reply With Quote
If you can get a second hand Lucas 14w motor - the rest of the wiper kit would be a lot less to buy !
We have a few reconditioned and tested motors that would reduce the cost of the kit by £25. The full kit will be cut to size and ready to fit on our car. The wiper system can be modified to park on either the left hand side, or the right hand side.
Regards Steve @ sVc
RK
posted on 17/12/09 at 01:40 PM Reply With Quote
I used a motor and assembly from a 3 wiper Lucas system from an MGB. Mount the motor solidly though, if not, you'll have all sorts of problems.
If doing again, I'd have gone to Steve at SVC and just bought a system from him, and if I have another brain problem and do this again, I will.
B Poccie? He zhayu... Ubau!! (EBay) Can't do Cyrillic here unfortunately!!
[Edited on 17/12/09 by RK]
Steve @ sVc
posted on 17/12/09 at 03:35 PM Reply With Quote
The MGB used the 14W Lucas wiper - 3 wipers for USA spec cars - 2 wipers for the rest of the world.
All the Cobra wiper kits we make for the Australian market are 3 wipers as they need a bigger swept area than over here.
GT40 cars are single wipers- all use the 14w motor.
The motor needs to be fitted with the metal strap that has a rubber strip fitted to it - and there is a rubber moulding that goes under the motor to keep it still and stop noises being transmitted to the car body. Although, on a "7" replica you may not hear this!
Steve @ sVc
