John P
posted on 16/12/09 at 09:47 AM |
How would I know if my hot water cylinder had an internal leak?
I have an ongoing problem with my heating and hot water system which uses a conventional Worcester boiler (not combi) with hot water cylinder and
header tank in the loft of our bungalow.
Following my previous post I have reduced the pump setting to avoid pumping over on the heating side but I still have serious air in the rads and have
to bleed some of them every week.
What's odd is that the hot water also has air in the pipes which leads me to suspect the hot cylinder as this is the only obvious place where
the heating circuit and hot water supply meet.
Because a replacement cylinder is so expensive I don't want to change it unless I'm sure that's the problem but how can I check.
John.
nitram38
posted on 16/12/09 at 10:05 AM |
The only way I would think is to pressure test your pipework. Either hire a plumber or pressure tester and do it yourself
Mr Whippy
posted on 16/12/09 at 11:18 AM |
Firstly where is the pump located? not in the loft is it?
John P
posted on 16/12/09 at 11:42 AM |
Mr Whippy
No, the pump is in a kitchen cupboard just below the wall hung boiler.
The hot water cylinder is in the loft adjacent to the cold and header tanks but all these are all some distance (probably 25 ft or so) from the boiler
location so the vent pipes etc have a fairly tortuous route up into the loft space and then across to the other side of the bungalow.
nige
posted on 16/12/09 at 12:34 PM |
you would see your hot water
colour change as the heating water would be leaking into the cylinder
very unlikely as the heating coil is
quite thick wall pipe
but hey im no expert just an enthusiastic
amatuer
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
posted on 16/12/09 at 12:37 PM |
It sound more like you have pipes that run uphill. Check that the pipe to the tank heater coil is not sloping down to it's feed, it only needs
to be a couple of degrees off level to cause problems and the vent pipe should be straight off this to your header tank. Also check the level in your
header tank as this can cause you problems with air in radiators.
thunderace
posted on 16/12/09 at 01:19 PM |
have you got a purg o matic on the exspantion tank
read this
http://www.inspectapedia.com/heat/AirBleedValves.htm
http://www.diynot.com/forums/viewtopic.php?t=66912
[Edited on 16/12/09 by thunderace]
RAYLEE29
posted on 16/12/09 at 02:26 PM |
Rusty coloured smelly hot water
personally i wouldnt have thought a leak in the coil would cause air in the rads as its submerged in water
sounds like a leak elsewhere you havent had new carpets fitted recently have you?
Ray![](/images//smilies/smile.gif)
hearbear
posted on 16/12/09 at 02:39 PM |
We had problems with air in rads all the time cured it by turning the boiler stat down as it was at max setting.
3.9Ltr SSC Stylus should be fun
RAYLEE29
posted on 16/12/09 at 04:07 PM |
mmm is it possible that the water in the pipes is boiling over venting to the header then drawing air back as it cools
Ray
Toltec
posted on 16/12/09 at 04:29 PM |
I had the same problem in my last house, the pump was in the 1st floor airing cupboard and I was pretty sure that it was pulling air in from the vent
pipe as the pump started up. When I fitted a new boiler I moved the pump downstairs and under the boiler and it did not happen again.
There are some pipework layouts on http://www.pumptool.co.uk/Position.html and details of their pros and cons.
The original layout in my house was none of the above, the pump was in the horizontal leg of an 'H' of piping. The expansion pipe was on
the inlet side of the pump and the fill from the header tank on the outlet side.
mangogrooveworkshop
posted on 16/12/09 at 04:35 PM |
porous copper perhaps
Puzzled
posted on 16/12/09 at 07:05 PM |
Hot water cylinder
IF the cylinder is situated in the attic near the storage tanks , I would ensure that the bottom of the storage tank is at least 3 feet higher than
the top of the cylinder. Its highly possible that you could be drawing air through the vent.
MkIndy7
posted on 16/12/09 at 07:21 PM |
Shut off the header tank for the hot water cylinder and run off all the hot water.
If it all runs off and stays run off without the Heating Header tank starting to fill then the coil is intact.
Simples ![](/images//smilies/bigsmile.gif)
