Author: Subject: Still need filler reducer
speedyxjs
posted on 22/12/09 at 09:02 PM Reply With Quote
I still havnt been able to find a reducer suitable for fuel that i can use to join my 51mm filler cap and my 45mm tank.
Someone suggested using a coolant reducer which i did only to be told that it needed to be fuel resistant
Does anyone know where i can find one?
Failing that, has anyone got a 45mm filler cap (preferable lockable) i can buy?
mcerd1
posted on 22/12/09 at 09:06 PM Reply With Quote
what about a metal reducer ?
(+ 2 short bits of fuel resistant hose)
[Edited on 22/12/09 by mcerd1]
speedyxjs
posted on 22/12/09 at 09:08 PM Reply With Quote
Where can i get them from? I have looked but havnt managed to find any.
mcerd1
posted on 22/12/09 at 09:11 PM Reply With Quote
make your own ?
failing that sketch something up and see if someone on here could do it for you
(I could but I'm not sure what stock metal I've got just now)
MakeEverything
posted on 22/12/09 at 09:12 PM Reply With Quote
why lockable?? The days of nicking fuel are gone are they not? Its not like the car is going to be parked outside overnight is it?
Kindest Regards,
Richard.
speedyxjs
posted on 22/12/09 at 09:13 PM Reply With Quote
Er, yes
For a few months is will be outside as i will lose the garage when it is finished
speedyxjs
posted on 22/12/09 at 09:15 PM Reply With Quote
Originally posted by mcerd1
make your own ?
failing that sketck something up and see if someone on here could do it for you
Not sure how to make one myself.
Miks15
posted on 22/12/09 at 09:24 PM Reply With Quote
how about this?
Bit of 50mm fuel hose should be able to be persuaded over your 51mm filler
mcerd1
posted on 22/12/09 at 09:28 PM Reply With Quote
^^ thats what I had in mind, but made to your spec if you couldn't find a suitable one
Volvorsport
posted on 22/12/09 at 11:00 PM Reply With Quote
get flak monkey to machine one for you .
i could roll some stainless , but i aint back at work until jan 4th.
www.dbsmotorsport.co.uk
getting dirty under a bus
Toltec
posted on 22/12/09 at 11:13 PM Reply With Quote
I think that's because modern production cars have anti-syphon gubbins fitted.
James
posted on 23/12/09 at 12:07 AM Reply With Quote
I've bloody well TWICE before told you how to do this!!!
http://www.locostbuilders.co.uk/viewthread.php?tid=122896
http://www.locostbuilders.co.uk/viewthread.php?tid=126088
James
speedyxjs
posted on 23/12/09 at 07:05 AM Reply With Quote
James
I know but i dont want one that leaks
