Numb nuts
posted on 27/12/09 at 03:18 PM |
Zetec-Type 9 clutch ??
I am putting a 2.0L black top Zetec / Type 9 gearbox into my Luego, using a lightened flywheel from Scholar Engineering.
The 1.8 silver top I took out does not have a compatible clutch (too small).
I am guessing the lightened flywheel was probably a 2.0L as the 2.0L clutch cover from the 2000 Focus I took the engine out of does fit it.
Does anyone know what clutch combination I need to make it all work out? ![](/images//smilies/sad.gif)
big_wasa
posted on 27/12/09 at 03:23 PM |
Early mondeo 240mm clutch with 23 spline 1" center and a a longer thrust bearing such as the cct 133 or what ever the number is.
Ive got mine in an mt75. just check yours fits the t9 bell housing.
big_wasa
posted on 27/12/09 at 03:27 PM |
Should do the job but the bearing will be of no use. ![](/images//smilies/smile.gif)
big_wasa
posted on 27/12/09 at 03:31 PM |
does it look like this ?
[img][/img]
![](/galpreviews/) ![](/gallery/)
Numb nuts
posted on 27/12/09 at 03:49 PM |
Yes, that's the one.
Numb nuts
posted on 27/12/09 at 04:29 PM |
Thanks for your help on this one I apprecaite it.
You mention the different bearing...what is it from? If you can find the part number it would be a great help. ![](/images//smilies/wink.gif)
big_wasa
posted on 27/12/09 at 04:33 PM |
a clutch release bearing from a 1972-1984 Ford Capri 1.6 OHC or 1970-1982 Ford Cortina 1.6 OHC (Quinton Hazell part CCT133)
cut and paste from another site. I bought the last one from ebay.
big-vee-twin
posted on 27/12/09 at 04:39 PM |
Yep the CT 133 is a longer bearing got min e from here recently for just under £20.00
link
http://www.triangleltd.com
Numb nuts
posted on 27/12/09 at 04:46 PM |
Thanks guys ![](/images//smilies/wink.gif)
big_wasa
posted on 27/12/09 at 05:59 PM |
I didnt think of them and I was there delivering last week. You have never seen so many bearings ![](/images//smilies/bigsmile.gif)
big-vee-twin
posted on 27/12/09 at 06:46 PM |
Think it was you Big W who put me onto them few weeks back
norfolkluego
posted on 27/12/09 at 09:07 PM |
They also sell them in Wilco down on Salhouse Road, £16 if I remember correctly, bought one from them a few weeks ago
Numb nuts
posted on 28/12/09 at 11:43 AM |
Thanks matey...hows the conversion going? ![](/images//smilies/bigsmile.gif)
norfolkluego
posted on 28/12/09 at 12:01 PM |
Not too bad, b*ggered about trying to adapt the old crossflow engine mounts for a while then gave up and made some new ones, engine's now in
(complete with new release bearing), Christmas (or more correctly Boddingtons) have slowed us down the last couple of weeks
