Author: Subject: what to bond my panels with?
Miks15
posted on 27/12/09 at 07:52 PM Reply With Quote
what to i need to buy to bond my interior panels to the chassis?
Something nice and cheap hopefully It will be bonded and then with a few rivets in.
cheers
Mikkel
ashg
posted on 27/12/09 at 08:26 PM Reply With Quote
pu adhesive click
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
austin man
posted on 27/12/09 at 09:16 PM Reply With Quote
silicone sealant is the cheaper alternative, its not over paintable though.
iank
posted on 27/12/09 at 09:21 PM Reply With Quote
and it doesn't actually bond the panel, so all the strength will come from the rivets (not actually bad if you have enough of the right sort, but worth knowing). If you do use silicone sealant don't get the kind that smells of vinegar.
Anonymous
mr henderson
posted on 27/12/09 at 09:30 PM Reply With Quote
There's a Wurth adhesive that is very popular, PU based, but most motor factors will do something similar such as Tiger Seal.
tegwin
any reputable car parts shop will stock commercial grade panel adhesive.... the kind of stuff that once stuck will never be unstuck!
Miks15
posted on 27/12/09 at 09:53 PM Reply With Quote
it will have a few rivets in it just to give it a bit of extra strength, but i dont want it so stuck it will be impossible to remove (im not planning on having to remove them, but just incase it is needed for some reason)
Would the PU sealant be the best option for this?
iank
posted on 27/12/09 at 10:08 PM Reply With Quote
Yes, it's tough but not impossible to get the panel off the chassis. Use a cheese wire approach.
See http://www.locostbuilders.co.uk/viewthread.php?tid=121065
Anonymous
Miks15
posted on 27/12/09 at 10:24 PM Reply With Quote
excellent, ill go for that then
Volvorsport
posted on 27/12/09 at 10:26 PM Reply With Quote
roberlo panel adhesive , polyureathane , cures in an hour .
www.dbsmotorsport.co.uk
getting dirty under a bus
Volvorsport
Volvorsport
Angel Acevedo
posted on 28/12/09 at 02:31 AM Reply With Quote
3m 5200 PU Adhesive Sealant
I have used this in the past while refurbishing a boat.
GREAT STUFF!!!
http://solutions.3m.com/wps/portal/3M/en_US/Marine/Home/Products/Catalog/?PC_7_RJH9U5230GE3E02LECIE20S4K7_nid=GSWWSBSW85beQH8HT14PGTgl
RK
posted on 28/12/09 at 02:21 PM Reply With Quote
PU'd and rivetted the forward ones (there are two), and velcroed the rearward ones. They really hold in place once the tunnel top sits on top (no glue, no rivets, no rivnuts).
geoffxt
posted on 28/12/09 at 03:50 PM Reply With Quote
I believe that Sikaflex is about the best available adhesive for this job. According to the maker's website some carmakers 'stick' car sections together and it might not be unreasonable to go without rivets on the side panels. If used I imagine that it will be difficult to take off any panels once they have been stuck on!
