The Baron
posted on 31/12/09 at 01:07 PM |
Clutch Cover for Pinto to Zetec Conversion
The only bit outstanding for the conversion is the clutch cover.
My engine is from a 1.6 Fiesta SI (zetec 16v)
I think the part number is Q10066, as i am going to use the existing pinto friction plate.
who knows of a really cheap supplier of clutch parts.
B
austin man
posted on 31/12/09 at 01:17 PM |
is the plate the correct size?? I thought the 1.6 zetec plate had a smaller centre than the input shaft on a type 9 ?
blakep82
posted on 31/12/09 at 01:34 PM |
what i did was go to a motor factor, and go through the catalog of clutch plates til i found one that fit the gearbox, and fit the flywheel.
the motor factor catalog will give all the info you need
i measured the clutch plate out my engine (220mm i think it was?) and i found a sierra clutch which was 215mm or something. wasn't much smaller
anyway. the guy that built my engine was quite happy it was up to the job anyway
________________________
t16turbotone
posted on 31/12/09 at 02:17 PM |
clutch catalogue for you to browse
http://www.spagweb.com/v8mini/tech_files/clutch_QH08.pdf
