mad-butcher
posted on 14/1/10 at 07:44 PM |
I'm sure I'll find a use for them
Bought 4 of these today
laser level
tony
Ben_Copeland
posted on 14/1/10 at 07:51 PM |
why 4????
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
martin1973
posted on 14/1/10 at 07:54 PM |
tracking?
martin
gottabedone
posted on 14/1/10 at 08:01 PM |
A few years ago there were some very good instruction on using 4 of these for tracking. From what I remember it was quite effective.
Ben_Copeland
posted on 14/1/10 at 08:02 PM |
ah i see, hope they are good enough quality
Ben
Roadster
RK
posted on 14/1/10 at 08:06 PM |
Why, are some lasers not straight? The less expensive lasers have bends in the beam or something???
MakeEverything
posted on 14/1/10 at 08:09 PM |
The hardest part would be setting up the datum from the chassis, so that it is square and true. Once youve got that, you can then measure to the
laser, to ensure both sides are the same.
With the laser being a flat line, you could probably set up camber as well as toe.
Kindest Regards,
Richard.
belgian2b
posted on 14/1/10 at 08:11 PM |
Hello,
i have a laser from that kind from Lidl.
I am not very happy of it.
The ray of light is straight, but not parallel to the body .
So, i always have to level the body before use the ray of light.
Gerardo
mangogrooveworkshop
posted on 14/1/10 at 09:21 PM |
Lazers that go round bends......should patent that...
posted on 14/1/10 at 10:26 PM |
No, the the beams aren't always completely parallel with the body of the level.
Toltec
posted on 14/1/10 at 11:27 PM |
Already done - it's called optical fibre ![](/images//smilies/wink.gif)
