NS Dev
| posted on 16/1/10 at 03:33 PM |
compressor motor overload, any electricians in the house for a quick answer??
Arggghhh mid very expensive paint job and the compressor has packed in.
Its tripping the single phase motor overload and the motor won't start properly.
The unloader switch is working properly,question really is, if the start capacitor is shot will that cause high run current and difficult starting?
I guess it will but want confirmation before I buy a capacitor!
cheers
Nat
philw
| posted on 16/1/10 at 03:35 PM |
Thats what happend to mine, new capacitor fixed it. hth
Must try harder
Stuart_B
| posted on 16/1/10 at 03:39 PM |
yes it will as the capitor is there to corect power factor, to near as unity as possible, and with out the capictor the current will lag the voltage
by more than it should.
hth
stuart
jacko
| posted on 16/1/10 at 03:41 PM |
And mine looking for a cheep capacitor at the mo
Nat will it start when the tank is empty ?
can it be the stop / start pressure switch?
Jacko
philw
| posted on 16/1/10 at 03:54 PM |
Jacko
I got my capacitor from a local electrical motor re-winders, about £15 iirc
Must try harder
MkIndy7
| posted on 16/1/10 at 05:00 PM |
Maplins do a range of motor start capacitors if your needing it today.
http://www.maplin.co.uk/Module.aspx?ModuleNo=30309
iank
| posted on 16/1/10 at 05:18 PM |
Phone the store before setting out, I've found their stock levels for components to be pretty poor over the last few years.
Anonymous
scotlad
| posted on 16/1/10 at 05:28 PM |
The capacitor is there to cause a phase shift inducing the rotor to turn. Without this phase shift there is no rotating magnetic field therefore the
motor stalls.Capacitor very likely popped as said
[Edited on 16/1/10 by scotlad]
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
