Author: Subject: Haybusa 08 > VortX Exhaust making
Triggerhappy
posted on 24/1/10 at 08:34 PM Reply With Quote
OOOhhhh had so much fun today in garage...messure, messure, messure,messure...and cut!
All primarys 22" whitin half an inch.
1,5" x 0,035" ss304 J-bends and tripple-Y from SPD exhust.
Next step will be welding.....
Inner of tripple-Y....Nice
Im from Sweden, so im escused...The Muppet drummer for president!!
prawnabie
posted on 24/1/10 at 08:39 PM Reply With Quote
Very nice work!
maximill666
posted on 24/1/10 at 08:40 PM Reply With Quote
Looks good
Triggerhappy
posted on 24/1/10 at 08:57 PM Reply With Quote
Other stuff....
Positive mould....will be used to make final mould and end product will be carbon fibre airbox....fed from 100mm ducting from pressure area in the nose front. Internal panelfilter Pipercross 140x 245mm.
Some pics on dash also....i made an CF hood for the dash now also...not in pics.
Drivers veiw...kind of...
[Edited on 24/1/10 by Triggerhappy]
aitch
posted on 24/1/10 at 11:38 PM Reply With Quote
nice only steering wheel on wrong side of car, easy mistake but sort it lol
aitch
sucksqueezebangblow
posted on 25/1/10 at 11:46 AM Reply With Quote
COOL! Like the Dash II! Should get mine up and running shortly!
JoaoCaldeira
posted on 26/1/10 at 10:47 AM Reply With Quote
VERY NICE!!!
Congrats on the exhaust work!
Triggerhappy
posted on 4/1/11 at 09:35 AM Reply With Quote
So, after an year with very little activity on this build...
Exhaust finaly welded up.
All welded with Solarflux to keep inside of pipes smooth without purging gas. Works quite well.
Welded up an bracket towards the rear and will do one more forward also...need to source harder "anti vibration" mounts thou.
Of cource brackets have "lightening holes"
[Edited on 4/1/11 by Triggerhappy]
Johneturbo
posted on 5/1/11 at 07:07 PM Reply With Quote
Exhaust looks great, how did you plan making it, did you just make 1 pipe at a time
i've cut up the standard bike manifold to use, but finding it hard to make a start with the design
is solaflux mig welding or tig
Triggerhappy
posted on 7/1/11 at 11:04 AM Reply With Quote
I made up my system from thin walled (save weight) pre bent J-Bends. i had 4" and 6" radius bends.
Given that my primary´s have an 36,3mm inner diameter i had an Hayabusa dragracer tuner calculate lenght and collector set-up for best powerband in upper register, given standard 1340cc cam/ignition.
so 22" primarys.
Meassured , meassured and played along with it until i got primarys whitin 1/2" from target.
The trickiest ones are the two middle cylinders...if you look closley the "in the car" rear middle one drops far below to gain length....
Solarflux is an powder you mix with ethanol and cover inner surface area with...when welding it (my welderguy did not die) acts as purgegas and minimize any welding residues on the inside. Worked bloody great!
My welder used TIG.
