posted on 25/1/10 at 07:27 AM |
Fastening the hood to the windscreen frame
This question sprung into my mind while reading the Singer sewing machine question - I thought I'd better start anew rather than hijack that
thread!
It's a simple question (but I bet I get 20 different answers! )
What's the best way to fasten a Flintstone's hood to the top of the windscreen frame?
Humbug
posted on 25/1/10 at 07:53 AM |
I'll start: I've got a Caterham screen and a Caterham hood, so it will attach with 7 poppers
Bluemoon
posted on 25/1/10 at 08:51 AM |
Along a similar lines, how do you make the hood go around the curve without a bit of extra material in the corners when you use poppers or similar
(will not apply if you use a "bow" to attach to screen)?
Dan
speedyxjs
posted on 25/1/10 at 09:04 AM |
My old MG had
Tenax Fasteners round the back of the hood which i always thought would be a good way of fastening a seven hood.
NigeEss
posted on 25/1/10 at 09:12 AM |
They'd be post SVA fitment though !
RichardK
posted on 25/1/10 at 09:33 AM |
I've done mine with a length of ali tubing going the width of the screen in a pocket with a fixed pin in one side and a thumb screw in the other
side. The same type of rod slides into a pocket for the bungee cord to clip on to.
Both rods are the same width as the cover so it all rolls up nice and fits in the same cover which is strapped behind the seats.
Rich
[Edited on 25/1/10 by RichardK]
Gallery updated 11/01/2011
mangogrooveworkshop
posted on 25/1/10 at 10:00 AM |
Our effort was a section of caravan slotted ali screwed to the top of the screen.
The hood has a bead sewn into it that slides in from the side.
The sailmaker also has the straps and buckles to make sure its tight enough as not to flap.
The other thing we have still to sort is the gutter flaps to make the water run off the back rather than down your arm.
Ivan
posted on 25/1/10 at 10:29 AM |
Yep - mast track on windscreen frame with bolt rope sewn into roof - pull it on like a sail. A completely waterproof solution. ![](/images//smilies/wink.gif)
chrsgrain
posted on 25/1/10 at 10:59 AM |
The way Dax do it, which works very well is to attach the material to a piece of U channel, which then fits upside down like 'n' on top of
the windscreen, and is held on at each end by an overcentre latch.
Got some pictures if you need them!
Chris
James
posted on 25/1/10 at 11:16 AM |
Got any pics?
- Muhammad Ali
mangogrooveworkshop
posted on 25/1/10 at 11:29 AM |
Yep I will post pix when I get home.
This was a progression picture before we sorted the sides.
[Edited on 25-1-10 by mangogrooveworkshop]
Danozeman
posted on 25/1/10 at 11:47 AM |
Have a look in Piddy's archive David. he did something similar to mango, Caravan awning channel on the top and stitched a bit of arial coax
into the roof so it simply slides in.
Very good and simple idea.
My westfield roof slots over the screen frame with a bit of plastic u channel with a thumb screw in a slot in the middle to fix it on.
Dan
wilkingj
posted on 25/1/10 at 12:10 PM |
Yup... Piddy's the Man for this
http://www.locostbuilders.co.uk/viewthread.php?tid=92042
[Edited on 25/1/2010 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
James
posted on 25/1/10 at 01:31 PM |
Thanks Mango
- Muhammad Ali
mangogrooveworkshop
posted on 25/1/10 at 01:57 PM |
roof linky
posted on 25/1/10 at 02:39 PM |
That channel looks perfect - I'm just approaching the glass-fitting stage, so I need to get this sorted pronto!
