Author: Subject: Aerocatches
The Venom Project
posted on 1/2/10 at 12:28 AM Reply With Quote
Aerocatches
Has anyone fitted these to a type seven car at all? If so what is the best way to do it? Any pics would be very useful indeed, do i fit the strike post first etc?
chris_harris_
posted on 1/2/10 at 09:08 AM Reply With Quote
I have four on my bonnet, easy to fit really.
I can get you some pics later today, but a search will find some results for you i think.
I have the flush fit ones, and they are sikaflexed to the underside, so nor fixings showing, they look really neat and are very secure too.
There is lots of adjustment in the pins, so they can be fettled afterwards.
Regards Chris
mcerd1
posted on 1/2/10 at 09:13 AM Reply With Quote
have you had a look on there website: linky
The Venom Project
posted on 1/2/10 at 10:29 AM Reply With Quote
Aerocatches
I looked on the website, but they don't really show how you fit them on a side fitting, I understand how to fit them top side, but not sure what is the best approach for side mount fitting into the bonnet.
Any pictures of this would be greatly appreciated and an idea of what I do first.
Vindi_andy
posted on 1/2/10 at 11:07 AM Reply With Quote
Fitted them to side of mine the pins need a bit of fiddling and I drilled the holes slightly wrong on mine but they still work.
Will try and dig out some photos later
GeorgeM
posted on 1/2/10 at 11:31 AM Reply With Quote
I bought some for mine but never fitted them.
Didn't want to drill holes that big through the chassis rails.
GeorgeM
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
mcerd1
posted on 1/2/10 at 11:56 AM Reply With Quote
^^ you could fit them without drilling the chassis....
first thing that comes to mind is welding a nut onto the top of the rail (as long a one as you can find or make something up in the lathe...) - then cut the pin down so that its short enough not to have to go through the rail (bit of trial and error) - that way its still adjustable and you could fit a locknut to stop it working loose
just a thought, I'm still tring to think of a way without welding......
[Edited on 1/2/10 by mcerd1]
cd.thomson
posted on 1/2/10 at 11:59 AM Reply With Quote
i will be fitting mine in the coming weeks, the instructions included are fairly comprehensive
Craig
MikeR
posted on 1/2/10 at 12:18 PM Reply With Quote
whats the cheapest place to get them?
(or what i really mean, is there anywhere cheaper than Rally Design?)
doddy
posted on 1/2/10 at 12:42 PM Reply With Quote
i have a set im about to fit has anyone used them to pass the iva wear they ok
cd.thomson
posted on 1/2/10 at 12:45 PM Reply With Quote
no reason why they shouldnt, the mechanism is sound and very secure.
also the recessed type don't put you at risk from dodgy projections unlike normal latches.
Craig
Steve Hignett
posted on 1/2/10 at 12:47 PM Reply With Quote
Have a gander at the Fury in the lower pics on this post (there's at least one at the bottom that are with the catches left open...)
http://www.locostbuilders.co.uk/viewthread.php?tid=115155
Vindi_andy
posted on 1/2/10 at 01:33 PM Reply With Quote
Passed SVA first time with them fitted and mine were the ones with the flange on the outside not the flush ones
The Venom Project
posted on 2/2/10 at 01:41 PM Reply With Quote
my catches are here :-)
Not wanting to sound like a complete bafoon, but what is the first thing to do? Do I mmount the strike post first and guess the centre of the eyelet? Or do I cut the hole for the catch and then find the centre from there.?
Any step by step pictures would be great, I must be being think here, I am sure I am not thinking hard enough.
cheers
Brommers
posted on 2/2/10 at 02:23 PM Reply With Quote
cheers
The packaging the Aerocatches come in doubles as a cutting guide. If you put the cardboard packaging on the bonnet, it'll show you how much of a hole you need to cut and also show you the line which the pin needs to take. Don't throw away the packaging before fitting them - and don't ask how I learned that lesson...
Vindi_andy
posted on 4/2/10 at 01:43 PM Reply With Quote
I fitted my catches first then the catch pin using the template as a guide then fettled the angle slightly
The Venom Project
posted on 4/2/10 at 01:47 PM Reply With Quote
catches
Marvelous, many thanks for that.
Nick
The Venom Project
posted on 6/2/10 at 05:46 PM Reply With Quote
Aerocatches fitted
After a bit of time and thinking about, I managed to get all 4 fitted in maybe 2 hrs, fabulous to see my bonnet fitted at last. Rescued attachment PIC_0309.JPG
Andybarbet
posted on 6/2/10 at 06:19 PM Reply With Quote
They looking great, i think im going to have to get some of them, loving the side repeaters too.
[Edited on 6/2/10 by Andybarbet]
The Venom Project
posted on 6/2/10 at 06:24 PM Reply With Quote
Cheers, Yeah they came off a Cooper, the pair of them new on eBay at £3, catches were worth the money I think
Andybarbet
posted on 6/2/10 at 06:42 PM Reply With Quote
Can you get them so all 4 locks are the same key ???
The Venom Project
posted on 6/2/10 at 06:49 PM Reply With Quote
Aerocatches fitted
I was hoping so, but it turns out that my 2 x sets have different keys, you get 4 keys per pair. The llok the part though.
