Numb nuts
posted on 4/2/10 at 10:50 AM |
Polo radiator question
Just bought a mk2 polo radiator for my Luego.
I assume some sort of temp. sender unit screws into the end cap, mid way between the top and bottom hose outlets.
Can anyone confirm what fits ...a part number etc would be really usefull...I need to source something.
Cheers Steve ![](/images//smilies/bigsmile.gif)
jollygreengiant
posted on 4/2/10 at 11:02 AM |
I can give you the CI part number (should be cross reference-able at good motor factors) ---C/IXEFS90 cost me £4.86+vat
Then you would need to get the sealing ring from Volks Wagen
[Edited on 4/2/10 by jollygreengiant]
Numb nuts
posted on 4/2/10 at 11:05 AM |
Thanks for that, am I right in assuming it's a temp. sender unit? ![](/images//smilies/wink.gif)
l0rd
posted on 4/2/10 at 11:17 AM |
isn't this the one that sends the signal to the fan to switch on?
Nash
posted on 4/2/10 at 11:19 AM |
I'm curous about this to?
If it is a sender what does it link to? I have a sender screwed into the engine block but I have to say I do have issues with innaccurate temp
readings.
If the temp sender in the rad is better it would save me a lot of grief.
Anyone?
..........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
tul214
posted on 4/2/10 at 11:22 AM |
The sender in the rad is the fan switch that turns the fan on at the desired temp. Part no. and the assosiated temps are in this
thread
1.6 Raw Super6 sold
norfolkluego
posted on 4/2/10 at 12:29 PM |
Bought one last week off eBay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350310155307
£6.99
snapper
posted on 4/2/10 at 12:57 PM |
An engine temp sender in a radiator is not a good idea, if the thermostat in the engine sticks shut you will not now, the temp sender in the rad will
read cool as the engine temp goes through the roof
I eat to survive
I drink to forget
ginger ninja
posted on 4/2/10 at 01:25 PM |
I've used the polo rad in a ZX9 BEC. I used a blanking plug.
The engine temp sensor should go in the engine , for reasons already mentioned re cooking block without knowing if thermostat fails to open.
The radiator fan does require a switch to control operation, which could be installed in the hole you are considering. Just check that the switch that
fits the hole has the right temperature switch point for the engine . (in my case bike engine runs at different temp to car switches I looked at.)
Ended up using an adjustable temperature switch with capilliary which we inserted into the rad top hose. Dearer at £25 but allows better control.
Numb nuts
posted on 4/2/10 at 04:55 PM |
thread
Reference the Thread...would the 50000 103-98C be right for my 2.0l Zetec Luego, knowing how they like to run hot.
tul214
posted on 4/2/10 at 05:53 PM |
This link seems to suggest the 50013 is the factory
part for a 2.0 zetec
Hope this helps,
Mark
1.6 Raw Super6 sold
hicost blade
posted on 4/2/10 at 06:22 PM |
It's for a fan switch/controller, the thread is M22 x 1.5
Breaker
posted on 4/2/10 at 07:12 PM |
I'm also looking for a radiator for my Indy R.
Using the search function on LCB I have found 2 different part numbers : VW2038 and VW302.
According to Mr Google these 2 partnumbers have the same dimensions. Am I overlooking something ?
norfolkluego
posted on 4/2/10 at 07:32 PM |
I bought a VW302 for my Luego recently, dimensions are 380 x 320 x 34 (strange metric millimetre things), fits lovely and very light compared to my
old one
Breaker
posted on 4/2/10 at 08:34 PM |
old one
The VW2038 has exactly the same dimensions. Anyone knows the difference ?
Numb nuts
posted on 4/2/10 at 09:14 PM |
The radiator Norfolkluego was told to get was the Polo MK2, which is what I bought...£35.95 on my door step via e-bay. Steve
norfolkluego
posted on 4/2/10 at 09:30 PM |
old one
Don't know but could it be something like the position of the inlet and outlet, mine are both on the left (looking forward from the engine bay,
perfect for a Zetec)
[Edited on 4/2/10 by norfolkluego]
norfolkluego
posted on 4/2/10 at 09:42 PM |
What mine looks like if that's any help
![](/galpreviews/a1089265-Rad1.JPG) ![Rescued attachment Rad1.JPG](/gallery/a1089265-Rad1.JPG) Rescued attachment Rad1.JPG
norfolkluego
posted on 4/2/10 at 09:45 PM |
piccy 2
![](/galpreviews/a1089269-Rad2.jpg) ![Rescued attachment Rad2.jpg](/gallery/a1089269-Rad2.jpg) Rescued attachment Rad2.jpg
Breaker
posted on 11/2/10 at 02:30 PM |
I think I have found a new radiator on the German eBay.
eBay Linky
Is this the famous Polo rad ? I'm a bit confused as the dimensions are 430 x 317
