Author: Subject: help with megasquirt
gordon h
posted on 4/2/10 at 05:36 PM Reply With Quote
hi all can anyone heip and direct me in the right direction, best place to buy megasquit, already built, thinking of fitting to saab 2.3 turbo,
bec is best but going to try sabb 2.3 turbo mk
rachaeljf
posted on 4/2/10 at 05:46 PM Reply With Quote
For MegaSquirt, I recommend http://www.extraefi.co.uk/
For Megasquit, I recommend Far Cotton Curry House .
Cheers R
DavidM
posted on 4/2/10 at 07:53 PM Reply With Quote
Cheers R
Excellent!
Proportion is Everything
madteg
posted on 4/2/10 at 08:47 PM Reply With Quote
Have fitted megasquirt to turbo. If i was doing it again i would pick one that could be tunned easily by a local rolling road as you will struggle with map on boost.
( food for thought )
flak monkey
posted on 4/2/10 at 08:53 PM Reply With Quote
Why have you struggled mapping on boost?
Northampton motorsport will rolling road tune megasquirt EU's
Sera
http://www.motosera.com
turboben
posted on 4/2/10 at 09:50 PM Reply With Quote
http://www.saabcentral.com/forums/showthread.php?t=125996
Must be someone on here with some info
fatbaldbloke
posted on 4/2/10 at 09:54 PM Reply With Quote
I set up my megasquirt fairly close using the wideband sensor, and then had it RR tuned at Jamsport in Northampton. The key, I find, is to get the ECU communications sorted out first and take your own laptop so the RR guys don't have to mess around sorting out version software compatibility, etc, which seems one of the biggest irritants with megasquirt.
