Author: Subject: bulk head seperating fuel tank/seats
stuleah
posted on 5/2/10 at 09:36 PM Reply With Quote
Ihave just been reading the IVA regs
11.
A Fuel Tank must not be located in, or form part of the passenger compartment, or other compartment integral with it and the bulkhead that separate the passengers from the fuel tank must be free from holes through which any escaped fuel could travel
will a flat panel suffice or does it need ends on it making it 3 sided?
Also can the tank be raised enough for the handbrake/gear cables to run underneath the tank or does it need to be mounted flat on the floor?
designer
posted on 5/2/10 at 10:20 PM Reply With Quote
A flat panel is OK, as it is to stop any flames reaching the cockpit.
The tank can be where you want, BUT, the lower the better.
stuleah
posted on 5/2/10 at 11:32 PM Reply With Quote
excellent thats what i was hoping. thanks
vinnievector
posted on 6/2/10 at 09:14 AM Reply With Quote
bulkhead
Hi , i made a stainless bulkhead for the mk . thought it necessary with the tank mounted at the rear this will offer protection from heat as well as petrol splash but there not lite.
jacko
posted on 6/2/10 at 09:10 PM Reply With Quote
11.
Hi my fuel tank is above the diff with the hand brake cables under it
stuleah
posted on 6/2/10 at 09:45 PM Reply With Quote
cheers for the info i think i will make mine out of ally, keep the wait down.
i should be able to do the same then and run the cables under it.
thanks
