westy turbo
posted on 11/2/10 at 06:21 AM |
Size bolts for rear driveshafts
Hi i was wondering if you can help me and let me know what size and steel grade should i go for my driveshafts -lobros bolts and is loctite needed.
thanks in advance
flak monkey
posted on 11/2/10 at 07:38 AM |
Should be 12.9 M8 cap heads, std fitment is torx head but they are a paint.
You shouldnt need loctite, but can use it if you want to.
Sera
http://www.motosera.com
Grimsdale
posted on 11/2/10 at 08:19 AM |
M8 x 50mm. you'll have to use allen head or torx type bolts, hex heads will foul the driveshaft. I got 12.9s which i think is pretty standard in
allen heads.
I've got a spare set if you want, say £4 + postage.
RAYLEE29
posted on 11/2/10 at 10:11 AM |
are they standard pitch? the prop ones are fine pitch (im being lazy) kinda assumed they would be too
Ray
Grimsdale
posted on 11/2/10 at 11:24 AM |
yep, standard pitch!
RAYLEE29
posted on 11/2/10 at 12:01 PM |
