Author: Subject: Bending 4mm strips of steel!
maskell01
posted on 18/2/10 at 08:58 PM Reply With Quote
Hi all!
i went a bit mental with the metal for the support strips for the front wheel arches and ended up with 4mm steel!
how would i go about bending it into the necessary shape?
not too sure the bender will cope!
would it be a matter of heating it,them letting it cool gradually?
cheers
Aaron
Daddylonglegs
posted on 18/2/10 at 09:02 PM Reply With Quote
That's what I would do. But someone less gash than me will be along soon I'm sure
blakep82
posted on 18/2/10 at 09:04 PM Reply With Quote
what sort of bend do you need? just a right angle? put it in a good solid vice, and batter it with a big hammer
with enough care, it can work pretty well.
________________________
Humbug
I think mine was 1/4" thick. I bent it cold in the bench vice, but my arms and pecs were aching by the time I finished!
MakeEverything
posted on 18/2/10 at 09:06 PM Reply With Quote
shouldnt matter if you coolit in a bucket of water. Its not load bearing, so it wont matter.
Kindest Regards,
Richard.
Daddylonglegs
posted on 18/2/10 at 09:27 PM Reply With Quote
Originally posted by MakeEverything....Its not load bearing, so it wont matter.
Depends how fast he's gonna be going
dhutch
posted on 18/2/10 at 09:45 PM Reply With Quote
Yeah, i would go for warming it up a bit, and whacking it in a vice.
- You could probably cold work it ok, but i would heat a bit to make life easier and the bend better. Allow to cool naturaly.
Daniel
steve m
posted on 18/2/10 at 10:49 PM Reply With Quote
4mm ?? mine is 5mm, and was bent over the wheel and tyre using spacers and a fing hammer
EASY
steve m
and no heat,
trextr7monkey
posted on 18/2/10 at 11:02 PM Reply With Quote
It's a man's life down in Sussex
tomprescott
posted on 18/2/10 at 11:48 PM Reply With Quote
When i do miine I'm going to use 10mm steel and bend it cold in my teeth!
blakep82
posted on 19/2/10 at 01:57 AM Reply With Quote
i'm not gonna tell you what i bent mine with
posted on 19/2/10 at 08:24 AM Reply With Quote
Mine are 5mm steel bar.
I used:
1) A big vice
2) A big hammer.
Job's a good 'un.
posted on 19/2/10 at 08:19 PM Reply With Quote
Have you seen the number of posts about wing stays breaking???
