Author: Subject: camber.
david cromie
posted on 27/4/04 at 11:38 PM Reply With Quote
camber.
I was told by mk.to put the mushroom narrow part to the front of the car, when I tried to set up the front to 1.5negative camber it would have meant that i would been unable to have a full lock nut on the top trackrod..The only way I could get the 1.5 neg. camber was to set the mushroom narrow edge to the inside of the car. Is there anything wrong in what I have done.Does this affect the camber?. How is the caster set-up David
posted on 28/4/04 at 08:33 AM Reply With Quote
it changes the KPI slightly, and also the amount of drag (castor effectively), but i doubt it will have a major effect on anything.
