Author: Subject: Bonding polypropylene sheet
bodger
posted on 20/2/10 at 01:33 PM Reply With Quote
Has anyone tried using PU adhesive on the black polypropylene trim sheet that MK supplies for covering the transmission tunnel. I want to bond a piece onto my R1 airbox so I can use it upside down (lower profile). The 'Direct Plastics' website suggests that it is very difficult to bond bu I'm sure I've head of people on here bonding the sheets to their chassis. If it's not going to be very strong I'll have to remake it in ally.
Airbox
Airbox
prelude1980
posted on 20/2/10 at 02:14 PM Reply With Quote
it won't be very strong and the only way to get it to stick it roughing up the polypropylene a lot to get a good key. personally i'd go with the ally
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
twybrow
posted on 20/2/10 at 02:48 PM Reply With Quote
Why not drill and rivet it as well? Use sealed rivets or fill them afterwards. That and a bead of PU should do it!
dhutch
posted on 20/2/10 at 02:51 PM Reply With Quote
Yeah i would go for a mechanical joint, its s slippy bugger.
- Rough it up a bit, pop rivets and a bead of pu to seal.
Daniel
Steve Hignett
posted on 20/2/10 at 02:57 PM Reply With Quote
What size is the piece of poly that you want to bond, I may have an offcut of carbon fibre that you can have for free that will bond with pu well...
dhutch
posted on 20/2/10 at 03:27 PM Reply With Quote
As i understand it he's trying to bond the two items in the photo.
- The cut out plate, the the PP air box.
- Simply using the panels as and example of another place pp is used.
However i would say the comparison is poor as it one thing to bond a non load bearing sheet with high contract area, and quite another to make a structural and airtight join! Particularly as the contact patch between two looks to be not amazing.
Daniel
bodger
posted on 20/2/10 at 03:54 PM Reply With Quote
The panel is PP, not sure what the airbox is made of. I think I'll try a few rivets with the PU to help secure it & if that doesn't work I'll get some 6mm PVC sheet & try that.
dhutch
posted on 20/2/10 at 04:04 PM Reply With Quote
Im only reading it off the photo, but it does appear to say PP on it...? Burn test?
posted on 20/2/10 at 04:52 PM Reply With Quote
I joined my airbox with resin and matting, it isn't on the road but it hasn't fallen apart in two years.
