maskell01
posted on 23/2/10 at 08:59 PM |
Suspension questions!
In the next month or so,ilk be biting the bullet and buying the suspension!
what length would i need?
the ones im looking at are the gaz shocks,are these any good?
cheers
Aaron
austin man
posted on 23/2/10 at 09:03 PM |
depends what your building, MK, Dax Locost, Haynes etc
Daddylonglegs
posted on 23/2/10 at 09:15 PM |
Got mine from here
Dave Ainsworth, sorted me out over the phone. Real nice chap.
maskell01
posted on 23/2/10 at 09:59 PM |
Its a locost based on the ron champion book!
flak monkey
posted on 23/2/10 at 10:06 PM |
I think it says in the book.
From memory I recall its something like 12" fronts and 11" rear for a book car.
Sera
http://www.motosera.com
iank
posted on 23/2/10 at 10:25 PM |
Procomp should be able to sort you out with correctly sized, sprung and valved protech shocks.
http://www.procomp.co.uk/shockdyno.html
Anonymous
Chippy
posted on 23/2/10 at 11:19 PM |
If you get on to the guy at GAZ he will tell you that the book is not correct, and tell you the correct lengths. HTH Ray
James
posted on 23/2/10 at 11:37 PM |
I would agree.
Pro-techs are also aluminium bodied so lighter and won't rust.
Matt really knows his stuff and builds a lot of race Locosts. He'll be able to tell you what you need.
James
- Muhammad Ali
bigfoot4616
posted on 24/2/10 at 05:05 PM |
just replaced my GAZ with protechs. the protech with a spring fitted is still quite a bit lighter than the GAZ with no spring fitted.
plus there valved correctly as well
